How to open a second window programmatically? [message #654894] |
Thu, 17 February 2011 09:37  |
My application has 2 windows at the moment. at startup the login window is visible, the registration window not. on the login window is a link which calls a command. this is the handler to close the login window and open the registration window:
public class ShowPart {
@Execute
public void execute(final MApplication application, final EModelService ms, final EPartService partService,
@Named("windowId") final String windowId) {
// find the window to show
MUIElement e = ms.find(windowId, application);
e.setVisible(true);
e.setOnTop(true);
e.setToBeRendered(true);
ms.bringToTop(e);
// hide the others
for (MWindow window : application.getChildren()) {
if (!windowId.equals(window.getElementId())) {
window.setVisible(false);
window.setOnTop(false);
window.setToBeRendered(false);
This successfully closes the login window but it doesn't open my registration window.
What am i doing wrong?
thank you for your help,
mike
Re: How to open a second window programmatically? [message #654966 is a reply to message #654894] |
Thu, 17 February 2011 13:56   |
Why are you creating Workbench-Windows and not simply open a
TitleAreaDialog, Dialog, Shell?
Tom
Am 17.02.11 15:37, schrieb Mike Moor:
> @Execute
> e.setVisible(true);
> e.setOnTop(true);
> ms.bringToTop(e);
> // hide the others
> mike
Re: How to open a second window programmatically? [message #654967 is a reply to message #654966] |
Thu, 17 February 2011 13:59   |
BTW naturally opening/closing MWindows should work but I think you can
get around using native SWT/JFace-Code.
Did you have a look in my tutorial? I've successfully opened there
windows programmatically but things might have changed since 4.0.
Tom
Am 17.02.11 19:56, schrieb Tom Schindl:
> Tom
>> Hi,
>> @Execute
>> e.setVisible(true);
>> e.setOnTop(true);
>> ms.bringToTop(e);
>> // hide the others
>> mike
Re: How to open a second window programmatically? [message #657523 is a reply to message #654967] |
Thu, 03 March 2011 02:44  |
I finally found the problem:
When one defines a not visible window in the Application.e4xmi, the "To Be Rendered" checkbox must not be checked!
As soon as i unchecked it my command handler did his job.
I still don't know why it behaves like that. maybe one of you guys knows the answer?
thanks for your help and for eclipse 4/e4! I love using it!
mike
FUDForum. Page generated in 0.03743 seconds
