Home » Language IDEs » ServerTools (WTP) » Include web project in another web project
Include web project in another web project [message #654519] Wed, 16 February 2011 03:04 Go to next message
Hi everyone!
I have a web project A that works quite fine. I have a servlet in a different web project B to works quite fine too Smile
Now I want to use some classes from project A in my project B and I somehow don't get it to work. I added project A to the dependencies of project B ("Project Properties ->Java Build Path -> Projects") and I am now able to use the classes from the "foreign" project. - But when I try to run project B on my local Tomcat server (via Debug as -> Debug on Server) Tomcat can't find the class files from project A, so I guess the are not deployed correctly.
As a workaround, I linked the complete src-folder from project A into my project B and that seems to work. But I doubt that that's the right way to do it.
I admit I'm new to this eclipse and web stuff. I found some discussions that seemed to point in the same direction, but none of them provided a solution I was able to use Smile
Hope I made my problems clear und gave you all the info you need - if not: let me know.
Regards: snellius
PS:
- Eclipse Java EE IDE for Web Developers. Version: Helios Service Release 1Build id: 20100917-0705
- apache-tomcat-7.0.8
Re: Include web project in another web project [message #654604 is a reply to message #654519] Wed, 16 February 2011 08:26 Go to previous messageGo to next message
On 2011.02.16 1:04, snellius wrote:
> Hi everyone!
> different web project B to works quite fine too :)
> to do it.
> solution I was able to use :)
> not: let me know.
> Regards: snellius
> PS:
Personally, I have always created a third project, a library, that
contributes to both projects A and B. However, I'm eager to hear what
others have to say about best practice.
Re: Include web project in another web project [message #654664 is a reply to message #654604] Wed, 16 February 2011 10:37 Go to previous messageGo to next message
>> Hi everyone!
>> to do it.
>> not: let me know.
>> Regards: snellius
>> PS:
Adding a dependency via Project Properties ->Java Build Path -> Projects
only creates a "build-time" dependency. Since JDT doesn't have any
notion of Java EE runtime dependencies, you will run into the expected
errors at runtime. For the right way to address both "build-time" and
Java EE runtime dependencies for shared classes, I agree with Russell.
Put the shared classes in a Utility Project and have both Dynamic Web
Projects depend on that Utility Project via the Deployment Assembly
page. Each published web project will get a jar in their WEB-INF/lib
that matches the name of the utility project and contains the shared
classes.
Larry
Re: Include web project in another web project [message #654671 is a reply to message #654664] Wed, 16 February 2011 11:09 Go to previous messageGo to next message
Larry Isaacs wrote on Wed, 16 February 2011 10:37
errors at runtime.
Yes, thanks for the explanation - that makes sense to me.
classes.
Larry
Thank both of you very much for this solution. This is a quite better way to do it.
Regards: snellius
Re: Include web project in another web project [message #654780 is a reply to message #654671] Thu, 17 February 2011 02:33 Go to previous messageGo to next message
Another thing though...
The reason for the setup I described is that the project which I wanted to "include" (project A) was developed by an external contractor and I am supposed to modify it as little as possible.
So - though the suggestions made here seem more reasonable - is it possible to do it in a different way in eclipse? Hopefully without messing with the build files "by hand"?
Thanks a lot:
Snellius
Re: Include web project in another web project [message #654893 is a reply to message #654780] Thu, 17 February 2011 09:22 Go to previous message
> Thanks a lot:
> Snellius
If you really want to make Project B "appear" to extend Project A, then
you would have to "include" what you needed from Project A in Project B
via linked folders, since there is no support for this via
"dependencies". One problem you may face is that you could end up with
two web.xml files in the "WebContent" portion of Project B. I'm pretty
sure there isn't any code in WTP to handle that scenario. I don't know
what behavior you will get in that case.
There may be a way to make this work if Project A can be modified, if
necessary, to support "inclusion". For example, the web.xml could be
put in a separate "WebContent" folder from the rest of the content,
allowing this other content to be "included" in Project B without
pulling in web.xml. The web.xml in Project B would have to duplicate
the one in Project A, plus any additions or modifications.
You may have to experiment to determine what expectations WTP has about
web.xml. For example, if you have multiple "WebContent" folders in a
project, are there any requirements about which one contains web.xml.
Does it need to be the first one listed on the Deployment Assembly page,
or will things work correctly regardless of which one it is in?
Larry
Previous Topic:Setting audio notification for server startup
Next Topic:javax.servlet.jsp.JspException cannot be resolved to a type
Current Time: Sat Jul 19 11:03:24 EDT 2025
Powered by FUDForum. Page generated in 0.03480 seconds
