Home » Eclipse Projects » GEF » Using direct edit(Problem in selecting the editable figure for second time)
Using direct edit [message #653372] Wed, 09 February 2011 10:04
Hi!
I have a graphical editor implemented by draw2d and GEF. Direct editing is implemented for one of the figures which is used for editing a label. The first time, after starting the editor, it is possible to select the text in the figure and edit it, and every thing is going well. But the second time it is not selectable. if we close the editor and reopen it, it will be again selectable.
I have checked if the editPart is still active, if it is selectable, if it is enabled and ... but I have not found the reason of the behavior.
Any help will be appreciated.
I have:
Eclipse 3.41
GEF 3.4.1
draw2d 3.4.1
Windows XP 32 bit
java 1.6.12
ant 1.7
Previous Topic:Obstacle-avoiding Manhattan router
Next Topic:MultiPageEditorActionBarContributor problems
Current Time: Sun Jul 20 10:39:06 EDT 2025
Powered by FUDForum. Page generated in 0.05590 seconds
