Home » Archived » M2M (model-to-model transformation) » simple UML2UML without results(I am trying to change the UML model name only, but no output!!!)
simple UML2UML without results [message #653135] |
Tue, 08 February 2011 10:59  |
Hi everybody,
I am trying to learn ATL by writing a simple trans. rule to modify the UML model name.
newModelName = 'Hello_'+oldModelName
But, I could not produce the new model I got an empty uml file.
Here is the source file
<uml:Model xmi:version="2.1" xmlns:xmi="http://schema.omg.org/spec/XMI/2.1" xmlns:uml="http://www.eclipse.org/uml2/3.0.0/UML" xmi:id="_mJ0SkTMXEeC_vp0B4E010A" name="MyModel"/>
The output:
<?xml version="1.0" encoding="ISO-8859-1"?>
<xmi:XMI xmi:version="2.1" xmlns:xmi="http://schema.omg.org/spec/XMI/2.1"/>
The ATL code:
--@path UML1=ALT ClassRefine/metamodel/UML.ecore
--@path UML2=ALT ClassRefine/metamodel/UML.ecore
module test1;
create OUT: UML1 from IN : UML2;
rule Model {
from
s : UML2!"uml::Model"
to
t : UML1!"uml::Model" (
__xmiID__ <- s.__xmiID__,
name <- 'Hello_' + s.name,
visibility <- s.visibility,
viewpoint <- s.viewpoint,
eAnnotations <- s.eAnnotations,
ownedComment <- s.ownedComment,
clientDependency <- s.clientDependency,
nameExpression <- s.nameExpression,
elementImport <- s.elementImport,
packageImport <- s.packageImport,
ownedRule <- s.ownedRule,
templateParameter <- s.templateParameter,
templateBinding <- s.templateBinding,
ownedTemplateSignature <- s.ownedTemplateSignature,
packageMerge <- s.packageMerge,
packagedElement <- s.packagedElement,
profileApplication <- s.profileApplication
Your hints and feedback are much appreciated...
[Updated on: Tue, 08 February 2011 11:36] by Moderator
Re: simple UML2UML without results [message #653149 is a reply to message #653135] |
Tue, 08 February 2011 11:32   |
Le 08/02/2011 16:59, Mohamed a écrit :
> Hi everybody,
> UML model name.
> But, I could not produce the new model I got a uml file with empty
> elements.
> The output:
> The ATL code:
> --@path UML=ALT ClassRefine/metamodel/UML.ecore
> module test1;
> create OUT: UML from IN : UML;
> rule Model {
> from s : UML!"uml::Model" to t : UML!"uml::Model" (
You may test the refining mode of ATL, in order to get a copy of the
input model with only the changes to write in your transformation.
Cordialement
Vincent MAHÉ
Ingénieur Expert - Projet IDM++ - Équipe AtlanMod
École des Mines de Nantes
La Chantrerie - 4, rue Alfred Kastler
B.P. 20722 - F-44307 NANTES Cedex 3
Tel: (33)2 51 85 81 00
Current Time: Sun Jul 20 05:35:32 EDT 2025
Powered by FUDForum. Page generated in 0.05512 seconds
