[EVL] Quick fixes are not found [message #652535] |
Fri, 04 February 2011 07:52  |
I followed the 'Live validation and quick-fixes in GMF-based editors with EVL' tutorial and adapted it to my own metamodel.
My purpose is to check a nameing convention as critique and offer a quick fix to fulfill the convention. This is very similar to the Folder quick fix in the tutorial mentioned above.
In cases where the convention is not fulfilled the Problems view shows a warning and the correct message. However, If I open the quick fix wizard, there is only an 'Ignore' fix available.
Is this a bug?
Sebastian
Re: [EVL] Quick fixes are not found [message #660222 is a reply to message #660216] |
Thu, 17 March 2011 09:01   |
Hi Dimitris,
When my NS-URI was not correct, the errors/warnings were not shown/found at all... Now, they are found correctly, but the fix is not.
About the code base, it is quite a large one with a few GMF editors working on one EMF model and on top of that - kind of confidential...
I will try to prepare a small example, which I can send you. In the meantime, you may thing of other reasons and tell me...
One more question, I do see the errors/warnings in the Problems view, but not in the Validation view that is provided by Epsilon? What is the cause for that?
Also, is it possible to switch on/off the some constraints as with the GMF Audits and EMF OCL (in Window/Preferences/Model Validation/Constraints)? What do I need to do in order to see the list of EVL-declared constraints there?
By the way, what was the cause in the case of Sebastian?
Greetings,
Hristina
FUDForum. Page generated in 0.06047 seconds
