Inferred superclasses [message #652705] |
Sat, 05 February 2011 13:02  |
I'm using artificial parser rules like
CommonSuperType: // unused
SubTypeA | SubTypeB | SubTypeC;
to get a super type inferred in the resulting model. While CommonSuperType should be never
called, the generation still complains about being able to match input using multiple
alternatives. Is it safe to ignore such a warning for an unused rule? And if so, is there
a way to get rid of the warning?
Also, is there a technique to make a class a subclass of another class without creating
artificial rules/classes and without affecting the grammar, solely for shaping the result
model? Like in,
TypeA: 'foo' name=ID;
TypeB: 'bar' name=ID;
is there a way to get TypeB to extend TypeA in the model? The closest thing I found is
TypeB returns TypeA:
{TypeB} 'bar' name=ID;
But this also changes the type of references to TypeB to TypeA.
Greetings,
Ralf
Re: Inferred superclasses [message #652716 is a reply to message #652705] |
Sat, 05 February 2011 15:15   |
Hi Ralf,
I bet it's time to refactor to an imported metamodel ;-)
You could try to use the postprocessor but I'd not recommend that.
Sebastian
Am 05.02.11 19:02, schrieb Ralf Ebert:
> CommonSuperType should be never called, the generation still complains
> about being able to match input using multiple alternatives. Is it safe
> to ignore such a warning for an unused rule? And if so, is there a way
> without creating artificial rules/classes and without affecting the
> grammar, solely for shaping the result model? Like in,
> thing I found is
> Greetings,
> Ralf
Re: Inferred superclasses [message #652738 is a reply to message #652732] |
Sat, 05 February 2011 18:46   |
Hi Ralf,
the transformation uses a somewhat limited algorithm to identify
uncalled rules. It does not work transitively. That explains your
observation.
Regarding your suggestion I doubt that the grammar is the right format
to define an ecore model thus I'd not introduce another concept for the
sake the generated metamodel.
Imported metamodels allow to define e.g. derived properties, super types
to factor common concepts into own types or define enum default values
explicitly.
Sebastian
Am 05.02.11 23:35, schrieb Ralf Ebert:
> Hi Sebastian,
> but except for the inheritance structure the inferred model is pretty
> ok; does managing this manually instead of generating it has other
> advantages besides the inheritance which would justify the additional
> effort to update the model everytime the grammar changes?
> Also, I digged a bit deeper; the warning happens because I try to get a
> supertype for a supertype, see my answer to Alexanders message for an
> example.
> I also wondered, just out of curiosity, wouldn't it make sense to have
> some kind of syntax to tell Xtext that some rule should extend some
> other rule, affecting only the model?
> For example, I would like to refactor this:
> TypedName:
> Parameter | Property | Assignment;
> Parameter:
> typeRef=TypeReference name=ID;
> Property:
> Assignment:
> typeRef=TypeReference name=ID '=' value=ProviderConstruction;
> to something like this:
> TypedName:
> Parameter extends TypedName;
> Property extends TypedName;
> Assignment extends TypedName:
> Ralf
Re: Inferred superclasses [message #653114 is a reply to message #653089] |
Tue, 08 February 2011 09:15  |
Hi Ralf,
it may be considered a bug but I doubt that we'll change this for indigo
since there are (unfortunately) clients out there that call this
unreachable rules reflectively.
Sebastian
Am 08.02.11 13:48, schrieb Ralf Ebert:
> Hi Sebastian,
>> not work transitively. That explains your observation.
> the gray coloring of rule names in the Xtext editor seems to know more
> about uncalled rules as far as I have observed - does it? Couldn't the
> same logic be used to not even generate such artificial rules in the
> grammar so that the antlr validation doesn't complain? For now, I really
> like the model being generated and so I'm ignoring the warnings because
> that seems to be the best compromise, but I'd rather not have anything
> in red font in the console... Is this considered a bug?
> Greetings,
> Ralf
FUDForum. Page generated in 0.04875 seconds
