Home » Archived » BIRT » Best practice for dynamically modifying a report
Best practice for dynamically modifying a report [message #652638] Fri, 04 February 2011 14:30 Go to next message
First let me start out by saying a big "thank you" for all the help you have been providing me recently.
Now for the question Wink
I have a Pie chart with data represented in items/second. I would like to add some form of interactivity that would allow the user to change the units to items/hour or items/day etc...
Obviously the math is easy to do in the script but I am looking for guidance as to:
1) the best way to interact with the user. Something like buttons to launch a script would do.
2) After changing the variable that would determine the units in the script I would need to refresh the report and I don't know how to do that easily.
Am I on the right track?
Re: Best practice for dynamically modifying a report [message #652651 is a reply to message #652638] Fri, 04 February 2011 15:09 Go to previous messageGo to next message
Mike,
I have written quite a bit about chart interactivity on Birtworld.
http://birtworld.blogspot.com/2008/10/dynamically-adding-ser ies-to-birt-chart.html
http://birtworld.blogspot.com/2009/08/using-script-to-modify -birt-chart.html
http://birtworld.blogspot.com/2009/12/calling-client-side-ja vascript-from.html
http://birtworld.blogspot.com/2010/05/more-on-chart-interact ivity.html
What you will probably need most is calling-client-side js and use that
in a combination with the report developed here:
http://birtworld.blogspot.com/2007/03/birt-milestone-5-new-a nd-notable.html
HTH
Jason
On 2/4/2011 2:30 PM, Mike Wulkan wrote:
> Now for the question ;)
> guidance as to:
> that easily.
Re: Best practice for dynamically modifying a report [message #652912 is a reply to message #652651] Mon, 07 February 2011 10:07 Go to previous messageGo to next message
Thanks Jason, these links are a goldmine... quick question though...
The script that reloads the page does so on a timer. How would I reference the function "reloadpage" manually from another script such as interactivity of an image button somewhere else in the report? For example a refresh button or just when the user changes a checkbox selection or something along those lines.
Re: Best practice for dynamically modifying a report [message #652984 is a reply to message #652912] Mon, 07 February 2011 14:07 Go to previous message
Just add a text element to the report that is set to html type and enter
something like this:
<INPUT type="button" value="Refresh" onclick="reloadpage()" />
Jason
Previous Topic:Y axis showing exponential value
Next Topic:Chart error in webviewer sample+Tomcat/JDK1.5
Current Time: Sun Jul 20 08:43:51 EDT 2025
Powered by FUDForum. Page generated in 0.27828 seconds
