Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Compare] Change comparison resource order
[EMF Compare] Change comparison resource order [message #648273] Wed, 12 January 2011 03:53 Go to next message
Hy,
I'm using EMF compare.
I have one file "File V1.xmi" and an other one "File V2.xmi".
When I select these files and choose "Compare with each other", "File V1" is always the left resource.
But my process is :
File V1 ----> evolutions ----> File V2
So I'd like to see what are the evolutions done in V2 (not what are the evolutions in V1...). How can I change the order ? (without renaming files name)
I don't know if my explanation is clear enough.....
Stef
[Updated on: Wed, 12 January 2011 03:54] by Moderator
Re: [EMF Compare] Change comparison resource order [message #651684 is a reply to message #648273] Tue, 01 February 2011 04:28 Go to previous messageGo to next message
Hi Stef!
I faced the same problem. The content of left/right tabs in Compare view don't depend on the order element were selected. It is confusing and misleading.
I looked through the EMF Compare bugzilla and didn't find a corresponding bug. I am debugging this functionality now. I'll let you know if i find any solution/explanation.
Best wishes,
Tanya.
Re: [EMF Compare] Change comparison resource order [message #652601 is a reply to message #651684] Fri, 04 February 2011 11:43 Go to previous message
So,
During debugging I found out that the problem repeats from Eclipse Core Compare functionality, and there it comes from Common Navigator. Common Navigator passes already sorted selected, where it is impossible to figure out which element was selected first.
I expected to find a lot of bugs or discussions about such important problem in the core functionality. Surprisingly, I found only Bug 109856 - [Actions] Comparing two folders in Navigator view uses fixed ordering, which was filed in 2005 and wasn't fixed since then.
It seams that there is no way to influence which tab will be right and which one will be left by the order they are selected.
Tanya.
Previous Topic:[EEF] RAP Support
Next Topic:Find referenced Objects
Current Time: Sun Jul 20 14:28:49 EDT 2025
Powered by FUDForum. Page generated in 0.08026 seconds
