Home » Eclipse Projects » EclipseLink » How to call Oracle function from eclipselink
How to call Oracle function from eclipselink [message #652481] Fri, 04 February 2011 04:06 Go to next message
Hi All,
I want to call oracle function which is getting two varchar parameter and returning one varchar.
I tried to use @NamedStoredProcedureQuery, but getting following error
04-Feb-2011 02:54:48:083 ERROR [pool-1-thread-1] - Error==
Internal Exception: java.sql.SQLException: ORA-06550: line 1, column 7:
PLS-00306: wrong number or types of arguments in call to 'RANDOMPIN'
PL/SQL: Statement ignored
Error Code: 6550
Call: BEGIN RandomPin(tpin=>?, p_msisdn=>?, p_stat=>?); END;
bind => [=> tpin, 00, G]
Query: ReadAllQuery(name="callTelePin" referenceClass=TelePin )
imran
Re: How to call Oracle function from eclipselink [message #652482 is a reply to message #652481] Fri, 04 February 2011 04:18 Go to previous messageGo to next message
Following is code of entity
@Entity
@NamedStoredProcedureQuery(
name="callTelePin",
resultClass=TelePin.class,
procedureName="RandomPin",
returnsResultSet=true,
parameters={
@StoredProcedureParameter(queryParameter="tpin" ,direction=Direction.OUT, jdbcType = Types.VARCHAR, type=String.class),
@StoredProcedureParameter(queryParameter="p_msisdn", direction=Direction.IN, type=String.class),
@StoredProcedureParameter(queryParameter="p_stat", direction=Direction.IN, type=String.class)
public class TelePin implements Serializable {
private static final long serialVersionUID = 1L;
public TelePin() {
super();
@Id
private String tpin;
private String p_msisdn;
private String p_stat;
public String getTpin() {
return tpin;
public void setTpin(String tpin) {
this.tpin = tpin;
public String getP_msisdn() {
return p_msisdn;
public void setP_msisdn(String p_msisdn) {
this.p_msisdn = p_msisdn;
public String getP_stat() {
return p_stat;
public void setP_stat(String p_stat) {
this.p_stat = p_stat;
and following is code snippet how i am calling
Query q2 = tabsEM.createNamedQuery("callTelePin");
q2.setParameter("p_msisdn", '3288009');
q2.setParameter("p_stat", "G");
tp = (TelePin) q2.getSingleResult();
System.out.println("Dear Customer, Your generated pincode is ="+tp.getTpin());
imran
[Updated on: Fri, 04 February 2011 04:19] by Moderator
Re: How to call Oracle function from eclipselink [message #652560 is a reply to message #652482] Fri, 04 February 2011 09:33 Go to previous messageGo to next message
Hello Imran,
This seems similar to http://www.eclipse.org/forums/index.php?t=msg&th=204031& amp;start=0&S=268bd545394728b9fcbdfb096c1c09a4
Can you provide the database stored proc signature? As in the linked post, you are also using the stored proc to return an incomplete entity - this will corrupt your cache, as the returned TelePin entity will be managed and only have the tpin id set.
Best Regards,
Chris
Re: How to call Oracle function from eclipselink [message #652562 is a reply to message #652560] Fri, 04 February 2011 09:37 Go to previous messageGo to next message
Thanks for reply infact this is not storedprocedure it is function and DBA provide access to me by this
CREATE OR REPLACE PACKAGE TABSMGR."W_VAS"
IS
-- Public function and procedure declarations
FUNCTION RandomPin (p_msisdn IN char, p_stat IN char)
RETURN char;
END W_VAS;
Re: How to call Oracle function from eclipselink [message #652977 is a reply to message #652560] Mon, 07 February 2011 14:39 Go to previous messageGo to next message
Hi chris,
Any update regarding how to call Oracle Function.
imran
Re: How to call Oracle function from eclipselink [message #653131 is a reply to message #652481] Tue, 08 February 2011 10:36 Go to previous message
@NamedStoredProcedureQuery only works with stored procedures, not functions.
You can use the StoredFunctionCall API to define a query using the function (using a SessionCustomizer, or DescriptorCustomizer).
You could also just define it as a @NamedNativeQuery,
"Select RandomPin(?, ?) from dual"
Previous Topic:@NamedStoredProcedureQuery & Out Parameter:
Next Topic:PostgreSQL/PostGIS stored function + Eclipselink converter problem
Current Time: Sat Jul 19 19:31:41 EDT 2025
Powered by FUDForum. Page generated in 0.05729 seconds
