All IElementUpdater objects referenced on startup issue [message #652403] |
Thu, 03 February 2011 13:33  |
In my application, it takes quite a long time to start up and see the workbench. I have noticed that every single one of my menu command handlers that implement IElementUpdater are having updateElement(...) called (sometimes multiple times) on startup before the window has even been shown. I have this to be true even if the menu items are not visible due to visibleWhen tags in place (menu items from different perspectives). I have noticed that if I use the activeWhen tag for the handler using the same constraints as the menu's visibleWhen tag, the handler will not have updateElement called on it. I can set this up for all my handlers that are specific to the perspective but for handlers that are shared amoung perspectives, I don't see a way to make it so that updateElement is not called on startup for non visible menu items. Does anyone know if it is by design that even though the menu items aren't visible, their active handlers are still updated or is this potentially a bug? Does anyone know of a way to tell a menu item in the plugin.xml to not update the handler when it isn't visible?
Max
FUDForum. Page generated in 0.04186 seconds
