Home » Newcomers » Newcomers » Wrapping text (Is there an option for this in the editor ?)
icon5.gif  Wrapping text [message #652331] Thu, 03 February 2011 10:37 Go to next message
In order to read the some source code well I've enlarged the font size to 14 , In a "heavy" code I often need to scroll the bottom bar to the right in order to see long code lines.
Is there an option in the editor (in this case I'm talking about the Java perspective) that the text will be wrapped up to be in the size of the window code ?
Rolling Eyes
Re: Wrapping text [message #652334 is a reply to message #652331] Thu, 03 February 2011 10:42 Go to previous messageGo to next message
Go to Source-> Format or use shorcut key Ctrl+ Shift + F. That does the word wrap. I guess that should help.
Animesh
Re: Wrapping text [message #652337 is a reply to message #652331] Thu, 03 February 2011 10:47 Go to previous messageGo to next message
On 2/3/2011 9:07 PM, Roey Peretz wrote:
> the window code ?
> :roll:
See Window > Preferences > ... > Formatter > Line Wrapping > Maximum
line width
Re: Wrapping text [message #652345 is a reply to message #652337] Thu, 03 February 2011 11:11 Go to previous messageGo to next message
Deepak Azad wrote on Thu, 03 February 2011 10:47
line width
Listen this only applies for the Ant's XML editor.
When I go to "Window > Preferences > Java > Code style > Formatter" there is no option to wrap text or to set "Maximum line width (characters)"
Rolling Eyes
[Updated on: Thu, 03 February 2011 11:12] by Moderator
Re: Wrapping text [message #652351 is a reply to message #652345] Thu, 03 February 2011 11:19 Go to previous messageGo to next message
Roey Peretz wrote on Thu, 03 February 2011 21:41
line width
Rolling Eyes
This option is available for Java also. In Java-> Code Style -> Formatter-> Under Active Profile, Click New and for the option "Initialize Setting with the following profile" you can choose whichever built in profile you want to use and then you will get another dialog which will have a tab for Line Wrapping. You can set your value there.
You can just check the availability of this feature by clicking Edit for built in Profiles, but you cannot change anything there for built in Profiles.
[Updated on: Thu, 03 February 2011 11:36] by Moderator
Re: Wrapping text [message #652367 is a reply to message #652351] Thu, 03 February 2011 11:56 Go to previous messageGo to next message
Animesh Kumar wrote on Thu, 03 February 2011 11:19
line width
Rolling Eyes
Where is "Initialize Setting with the following profile" option ?
I've created new profile in "Window > Preferences > Java > Code style > Formatter" called MyForm I've edited it to "wrap text whenever necessary" pressed OK then Apply then another OK and nothing happens.
It is my active profile in the Java editor.
When I press Ctrl+Shift+F it doesn't format the code as I defined in MyForm.
Confused
[Updated on: Thu, 03 February 2011 11:57] by Moderator
Re: Wrapping text [message #652378 is a reply to message #652367] Thu, 03 February 2011 12:22 Go to previous messageGo to next message
Roey Peretz wrote on Thu, 03 February 2011 22:26
line width
Rolling Eyes
Confused
Have you changed the Line Wrapping Policy in Line Wrap Tab for each element in the List Box. Try Changing it for:-
Constructors ,Methods Declaration, Function Calls, Expressions, and Statements to "Wrap all elements, every element on a new line". I tried this using font size 14 and Maximum Line Width 40 and it worked for me. It should work for you also. Smile
Animesh
icon14.gif  Re: Wrapping text [message #652393 is a reply to message #652378] Thu, 03 February 2011 13:00 Go to previous message
Animesh Kumar wrote on Thu, 03 February 2011 12:22
line width
Rolling Eyes
Confused
Animesh
At last...the answer was "Window > Preferences > Java > Code style > Formatter > Configure Project Specific Settings..."
And then select a project from the list press OK and activate MyForm on it...
THNX ALOT my dear friend
Smile
Previous Topic:Send Serialized data from Applet to Servlet and Ack from Servlet
Next Topic:Basic Export Question
Current Time: Sun Jul 20 08:10:21 EDT 2025
Powered by FUDForum. Page generated in 0.09071 seconds
