Home » Modeling » EMF » extend Ecore-Editor
extend Ecore-Editor [message #652352] Thu, 03 February 2011 11:22 Go to next message
Hey guys,
I would like to create an eclipse-plugin. What I want is the following
I have an open Textfile in an editor in eclipse. Once I push a certain button I want the file to be displayed in the text editor as well as in the "sample ecore model editor". (The content of the text-file is somehow already connected with an ecore file so thats no problem).
But how do i get the ecore-editor to open with that file?
I was also thinking about extending the "sample ecore modeling editor" to add some personal features. Is there any possibility to do so? Couldn't find anything regarding that topic
regards
golden_wing
Re: extend Ecore-Editor [message #652419 is a reply to message #652352] Thu, 03 February 2011 14:50 Go to previous messageGo to next message
Comments below.
golden_wing wrote:
> Hey guys,
What's so special about the sample editor that's different from what you
get for your generated editor?
You can look at how the generated wizards opens an editor.
Again, why not use the generated editor?
> regards
> golden_wing
Re: extend Ecore-Editor [message #652486 is a reply to message #652352] Fri, 04 February 2011 04:28 Go to previous messageGo to next message
I want to create a perspective. In this one I want the Editor to my FIle (its an Xtext-generated Editor) on the left side of my screen and on the right side the corresponding ecore editor.
I just wasn't able to add the ecore model editor to a perspective, and i don't want, that the user has to add it himself. The new perspective should already include this right away.
Re: extend Ecore-Editor [message #652498 is a reply to message #652486] Fri, 04 February 2011 05:01 Go to previous messageGo to next message
Comments below.
So why not the generated EMF editor?
That has nothing to do with whether you use the sample editor on the
generated editor. It sounds to me like you should be using the
generated editor, or perhaps better still, extend your Xtext editor to
include whatever aspects of the generated editor you'd like to keep; I
don't know if that's feasible mind you.
Re: extend Ecore-Editor [message #652684 is a reply to message #652352] Sat, 05 February 2011 04:41 Go to previous messageGo to next message
Well it doesn't have to Be the Sample Editor i also found the generic emf Editor pretty nice. However I'm not sure what you mean with the generated Editor. Couldn't find it.
Still I'm Not able to add one of These Editors to a defined perspective. Again - the perspective should already be defined in the plugin
[Updated on: Sat, 05 February 2011 04:42] by Moderator
Re: extend Ecore-Editor [message #652686 is a reply to message #652684] Sat, 05 February 2011 04:51 Go to previous messageGo to next message
Am 05.02.2011 10:41, schrieb golden_wing:
What do you mean by "add"? I'm not an RCP expert but I think you can not add editors to a perspective declaratively. Only views and one *area* for all editors that will be opened at runtime.
Cheers
/Eike
http://www.esc-net.de
> Again the perspective should already be defined in the plugin
Re: extend Ecore-Editor [message #652797 is a reply to message #652352] Sun, 06 February 2011 16:04 Go to previous message
Ok forget about the "add"-Aspect Wink Figures out, that I can't just add this editor. Though I can add Editors to a plugin and connect them with a specific file-extension.
Does anybody know, where to find the Class and corresponding Contributor to the org.eclipse.emf.genericEditor?
Previous Topic:EContentAdapter on BPMN EMF model
Next Topic:[Teneo] Forcing a Timestamp data type for a column when PersistenceOptions.DEFAULT_TEMPORAL_VALUE, &
Current Time: Sat Jul 19 06:54:23 EDT 2025
Powered by FUDForum. Page generated in 0.03284 seconds
