Re: Wrapping text [message #652378 is a reply to message #652367] |
Thu, 03 February 2011 12:22   |
Roey Peretz wrote on Thu, 03 February 2011 22:26 | Animesh Kumar wrote on Thu, 03 February 2011 11:19 | Roey Peretz wrote on Thu, 03 February 2011 21:41 | Deepak Azad wrote on Thu, 03 February 2011 10:47 |
See Window > Preferences > ... > Formatter > Line Wrapping > Maximum
line width
Listen this only applies for the Ant's XML editor.
When I go to "Window > Preferences > Java > Code style > Formatter" there is no option to wrap text or to set "Maximum line width (characters)"
This option is available for Java also. In Java-> Code Style -> Formatter-> Under Active Profile, Click New and for the option "Initialize Setting with the following profile" you can choose whichever built in profile you want to use and then you will get another dialog which will have a tab for Line Wrapping. You can set your value there.
You can just check the availability of this feature by clicking Edit for built in Profiles, but you cannot change anything there for built in Profiles.
Where is "Initialize Setting with the following profile" option ?
I've created new profile in "Window > Preferences > Java > Code style > Formatter" called MyForm I've edited it to "wrap text whenever necessary" pressed OK then Apply then another OK and nothing happens.
It is my active profile in the Java editor.
When I press Ctrl+Shift+F it doesn't format the code as I defined in MyForm.
Have you changed the Line Wrapping Policy in Line Wrap Tab for each element in the List Box. Try Changing it for:-
Constructors ,Methods Declaration, Function Calls, Expressions, and Statements to "Wrap all elements, every element on a new line". I tried this using font size 14 and Maximum Line Width 40 and it worked for me. It should work for you also.
Animesh
Re: Wrapping text [message #652393 is a reply to message #652378] |
Thu, 03 February 2011 13:00  |
Animesh Kumar wrote on Thu, 03 February 2011 12:22 | Roey Peretz wrote on Thu, 03 February 2011 22:26 | Animesh Kumar wrote on Thu, 03 February 2011 11:19 | Roey Peretz wrote on Thu, 03 February 2011 21:41 | Deepak Azad wrote on Thu, 03 February 2011 10:47 |
line width
Animesh
At last...the answer was "Window > Preferences > Java > Code style > Formatter > Configure Project Specific Settings..."
And then select a project from the list press OK and activate MyForm on it...
THNX ALOT my dear friend
FUDForum. Page generated in 0.09186 seconds
