Home » Modeling » EMF » EObject#eSet and autoboxing
EObject#eSet and autoboxing [message #652229] |
Thu, 03 February 2011 04:37  |
I've been run into troubles using eSet, primitive values and autoboxing
(in conjunction with databinding where I was able to fix the problem).
Suppose you have the following feature:
-----------8<-----------
private long myLongFeature;
public void setMyLongFeature(long myLongFeature) {
public void eSet(int featureID, Object newValue) {
switch (featureID) {
setMyLongFeature((Long)newValue);
Now the problem is that when databinding under certain circumstances
converts a String to a number it can happen that the eSet-Method is
called with an int-value which results in ClassCastException because an
int is converted to Integer and the cast above fails.
My question now is would it be better if we'd make the eSet get
generated like this:
setMyLongFeature(((Number)newValue).longValue());
My understanding of autoboxing is that this is more or less what the
compiler makes from setMyLongFeature((Long)newValue) anyways because at
the bytecode level you'll get something like this:
setMyLongFeature(((Long)newValue).longValue());
This way a call to myinstance.eSet(MY_LONG_FEATURE,10) works like
myinstance.setMyLongFeature(10).
So my suggestion would be to make the eSet-code behave like statically
typed Java method calls in terms of primitive conversion (for types like
long/double this is as easy as shown above) for other types the
primitive conversion rules have be taken into account.
Tom
Re: EObject#eSet and autoboxing [message #652254 is a reply to message #652229] |
Thu, 03 February 2011 05:36   |
Tom,
Comments below.
Tom Schindl wrote:
As it should...
It's never been the intention for eSet to do any kind of type
conversion. In the case of int you'd do the same, and if you passed a
long that was too big, it would just truncate the value...
I don't think this is a great idea. It makes all numbers
interchangeable in any direction, some of them lossy. That's just not
the intent...
> Tom
Re: EObject#eSet and autoboxing [message #652256 is a reply to message #652254] |
Thu, 03 February 2011 06:06   |
Is it really a conversion when we talk about primitives? Isn't every int
a long - so to any method I can pass a long I'm free to pass an int,
short, char, byte?
> the intent...
This is certainly NOT true for double/long as you wrote "some of them
lossy".
Would it change your opinion when I tell you that Java-Reflection does
what I request here?
> import java.lang.reflect.Method;
> public class TestReflection {
> public static void setLong(long l) {
> System.err.println("Long: " + l);
> public static void setInt(int i) {
> System.err.println("Integer: " + i);
> public static void setShort(short s) {
> System.err.println("Short: " + s);
> public static void setDouble(double i) {
> System.err.println("Double: " + i);
> * @param args
> public static void main(String[] args) {
> // TODO Auto-generated method stub
> try {
> Method m = TestReflection.class.getMethod("setLong", new Class[] { long.class });
> m.invoke(null, new Object[] { 10 } );
> m = TestReflection.class.getMethod("setDouble", new Class[] { double.class });
> m.invoke(null, new Object[] { 10L } );
> m.invoke(null, new Object[] { 10f } );
> //WILL FAIL m = TestReflection.class.getMethod("setInt", new Class[] { int.class });
> // m.invoke(null, new Object[] { 10L } );
> //WILL FAIL m = TestReflection.class.getMethod("setShort", new Class[] { short.class });
> // m.invoke(null, new Object[] { 10 } );
> } catch (Exception e) {
> // TODO Auto-generated catch block
> e.printStackTrace();
So it looks like Java-Reflection has certain rules when it comes to
primitive types when called reflectively.
To a method with:
* double: you can pass Double,Float,Long,Integer,Short,Character,Byte
* float: you can pass Float,Integer
* long: you can pass Long,Integer,Short,Character,Byte
Tom
Re: EObject#eSet and autoboxing [message #652418 is a reply to message #652256] |
Thu, 03 February 2011 14:48   |
--------------000000080702080309020700
Tom,
Comments below.
> short, char, byte?
Well of course the issue is, how does this generalize?
>> the intent...
> lossy".
Actually it's is true for Double->Long.
Not necessarily. Complexity is something that is often best avoided.
So something that's not been an issue for almost 10 years might be
better off left as is.
>> * @param args
>> try {
I guess the question is, what are the rules?
> To a method with:
So conversions that are statically know to be non-lossy... But how to
capture these rules in generated code? Are the subclasses of Number
bounded?
It' seems
> Tom
<html>
<head>
http-equiv="Content-Type">
</head>
Tom,<br>
<br>
Comments below.<br>
<br>
Tom Schindl wrote:
<blockquote cite="mid:iie1s1$9p2$1@news.eclipse.org" type="cite">
<pre wrap="">[...]
</pre>
<blockquote type="cite">
<pre wrap="">It's never been the intention for eSet to do any kind of type
</pre>
</blockquote>
<pre wrap=""><!---->
short, char, byte?
</pre>
</blockquote>
Well of course the issue is, how does this generalize?<br>
<pre wrap="">
</pre>
<pre wrap="">-----------8<-----------
</pre>
</blockquote>
<pre wrap="">I don't think this is a great idea. It makes all numbers
the intent...
</pre>
</blockquote>
lossy".
</pre>
</blockquote>
Actually it's is true for Double->Long.<br>
<pre wrap="">
</pre>
</blockquote>
Not necessarily.
Re: EObject#eSet and autoboxing [message #652426 is a reply to message #652418] |
Thu, 03 February 2011 15:22  |
Am 03.02.11 20:48, schrieb Ed Merks:
> Tom,
> Comments below.
>> short, char, byte?
>>> the intent...
>> lossy".
I meant there's not potential loss for methods who get passed in a
double or long ;-)
>> To a method with:
> bounded?
I'll try to find that out ;-)
Tom
Current Time: Sun Jul 20 02:30:10 EDT 2025
Powered by FUDForum. Page generated in 0.04326 seconds
