Handling saving/ dirty state over multiple files [message #651797] |
Tue, 01 February 2011 11:08  |
Hi folks,
we are working on a emf editor based on a relatively simply model. Now we have the requirement to expand the dirty state on another file.
This is because of we import data into our model and want to handle it transient, but when sth of the data is changed the data should be saved back into the formerly loaded file.
Is there sth build in in EMF to handle this use-case or do we have to realize this by our own ?
Thank you...
Re: Handling saving/ dirty state over multiple files [message #651800 is a reply to message #651797] |
Tue, 01 February 2011 11:14   |
--------------040700000303020801080909
Philipp,
Does this option help?
* A save option that can be used only with {@link #save(Map)}
* to specify that the resource is to be saved only if the new
contents
* are different from actual contents;
* this compares the bytes in the backing store against the new
bytes that would be saved.
* The value on this option can be either <code>null</code>,
* {@link #OPTION_SAVE_ONLY_IF_CHANGED_FILE_BUFFER},
* or {@link #OPTION_SAVE_ONLY_IF_CHANGED_MEMORY_BUFFER}.
* @since 2.3
String OPTION_SAVE_ONLY_IF_CHANGED = "SAVE_ONLY_IF_CHANGED";
Resource.setTrackingModification might help too...
philipp huebner wrote:
> Hi folks,
> Thank you...
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Philipp,<br>
<br>
Does this option help?<br>
<blockquote><small> /**</small><br>
<small> * A save option that can be used only with {@link
#save(Map)}</small><br>
<small> * to specify that the resource is to be saved only if the
new contents</small><br>
<small> * are different from actual contents; </small><br>
<small> * this compares the bytes in the backing store against the
new bytes that would be saved.</small><br>
<small> * The value on this option can be either
<code>null</code>, </small><br>
<small> * {@link #OPTION_SAVE_ONLY_IF_CHANGED_FILE_BUFFER},</small><br>
<small> * or {@link #OPTION_SAVE_ONLY_IF_CHANGED_MEMORY_BUFFER}.</small><br>
<small> * @since 2.3</small><br>
<small> */ </small><br>
<small> String OPTION_SAVE_ONLY_IF_CHANGED = "SAVE_ONLY_IF_CHANGED";</small><br>
</blockquote>
Resource.setTrackingModification might help too...<br>
<br>
<br>
<blockquote cite="mid:ii9aqt$d2i$1@news.eclipse.org" type="cite">Hi
folks,
<br>
<br>
<br>
<br>
Thank you...
<br>
</blockquote>
</body>
</html>
--------------040700000303020801080909--
Re: Handling saving/ dirty state over multiple files [message #652423 is a reply to message #652330] |
Thu, 03 February 2011 14:59  |
Philipp,
Comments below.
> ok after many hours knopcking my head against the wall i got sth ....
> i implemented my resource and factory; but how can i create a model,
How does the generated wizard do that?
> add this model as a child to a node in my main model
Is his a containment reference or a non-containment reference?
> and seralize it by resource doLoad() ....
I guess you mean deserialize.
> Excuse my dump questiomns but this is really a hard struggle without
> examples or anything ...
FUDForum. Page generated in 0.60652 seconds
