Home » Modeling » Papyrus » Diagram palette customization: "Set list of applied stereotypes" bug?
Diagram palette customization: "Set list of applied stereotypes" bug? [message #650742] Wed, 26 January 2011 05:57 Go to next message
Hi all,
I am trying to use the Papyrus MDT diagram palette customization tool. My profile is applied to the model and is working fine.
However, when I create the Aspect Action "Set stereotypes to be applied" and then click on the "Plus" button for adding a stereotype to apply, nothing happens. Have someone had a similar trouble? Is it a bug?
Wladimir
Re: Diagram palette customization: "Set list of applied stereotypes" bug? [message #650996 is a reply to message #650742] Thu, 27 January 2011 07:15 Go to previous messageGo to next message
This is a bug. I'll try to look into the code to see what's wrong.
Cheers
Rémi
Re: Diagram palette customization: "Set list of applied stereotypes" bug? [message #651795 is a reply to message #650996] Tue, 01 February 2011 11:04 Go to previous messageGo to next message
Hi Remi,
do you plan fix this bug for the 7.2 version?
Wladimir
Re: Diagram palette customization: "Set list of applied stereotypes" bug? [message #652038 is a reply to message #651795] Wed, 02 February 2011 08:50 Go to previous messageGo to next message
Hi Wladimir,
the release 0.7.2 has already been done a few weeks ago. The maintenance version 0.7.3 is not planned yet.
I think this bug won't be fixed in the next weeks, as Papyrus team is more involved in the development of Papyrus 0.8 version for Indigo.
If I take this action in charge, I will inform you.
Rémi
Re: Diagram palette customization: "Set list of applied stereotypes" bug? [message #668015 is a reply to message #650742] Tue, 03 May 2011 08:06 Go to previous messageGo to next message
I have the same problem as Wladimir, has anyone found a solution?
Thanks.
Miriam
Re: Diagram palette customization: "Set list of applied stereotypes" bug? [message #673307 is a reply to message #668015] Mon, 23 May 2011 03:59 Go to previous message
I will check withe colleagues, if this bugs remains. If this the case a bug wil be raised.
Previous Topic:SySML Requirement Diagram creation problem
Next Topic:Nullpointer on class diagram.
Current Time: Sun Jul 20 10:42:06 EDT 2025
Powered by FUDForum. Page generated in 0.04298 seconds
