Re: Apply stereotypes to InstanceSpecification [message #651672 is a reply to message #651667] |
Tue, 01 February 2011 03:22  |
you will find some documentation about profiles on the first document located in the documentation area of Papyrus web site: http://www.eclipse.org/modeling/mdt/papyrus/usersTutorials/u sersTutorialsIndex.php
According to your explanation, it seems that your stereotype does not extends the InstanceSpecification metaclass. For this, when you model your profile, you should select the "import metaclass" tool in the palette and click on the diagram. In the dialog that opens, select the InstanceSpecification and add it to the right side of the dialog.
Then create an extension link starting from your stereotype and targeting the metaclass InstanceSpecification. Then save the profile and answer yes when it asks for definition.
Once you have done this, you apply this profile on your model. This should give you access to your stereotype on instance specifications.
HTH
Rémi
FUDForum. Page generated in 0.05214 seconds
