Home » Archived » M2M (model-to-model transformation) » [ATL] UML Component with stereotypes issue
[ATL] UML Component with stereotypes issue [message #651258] |
Fri, 28 January 2011 10:27  |
hello all,
i was wondering if anyone here could help me with this problem i'm having using ATL:
i'm writing a transformation from an UML Profile to another metamodel. Whenever i found an UML Component in the source metamodel with a particular Stereotype applied, i have to transform it in an element of the target mm. Then i have to set some attributes of this element with values from the properties of the Stereotype.
I used "getAppliedStereotypes()" to check if the Stereotype is applied to the Component and it works To read the value of the properties i wanted to use "getValue(...)", but when i try to run the transformation a i get an error saying that the operation is not found which is strange because Component should inherit it from Element.
Have you got any piece if advice? i'm pretty new to ATL so any help wold be welcomed.
Nicholas
BTW, here's a piece of the transformation:
module chess2dim;
create OUT : DependabilityintermediateModel from IN : UML2;
rule StatefulHardware2DIMComponent {
from
sfh : UML2!Component (sfh.getAppliedStereotypes()-> exists(e| e.name = 'StatefulHardware'))
to
c : DependabilityintermediateModel!Component (
Name <- sfh.name,
intermediateModel <- UML2!Model.allInstances()->first(),
Faults <- ft,
Errors <- e
fo : DependabilityintermediateModel!Exponential(
Rate <- sfh.getValue(sfh.getAppliedStereotype('CHESS-ML::StatefulHardware'), 'faultOcc')
...and this is the exception i get:
org.eclipse.m2m.atl.engine.emfvm.VMException: Operation not found: IN!ComponentA.getValue(org.eclipse.m2m.atl.engine.emfvm.lib.OclUndefined,java.lang.String)
at __applyStatefulHardware2DIMComponent#63(chess2dim.atl[24:12-24:92])
local variables: self=chess2dim : ASMModule, link=TransientLink {rule = StatefulHardware2DIMComponent, sourceElements = {sfh = org.eclipse.uml2.uml.internal.impl.ComponentImpl@1946e0c (name: ComponentA, visibility: <unset>) (isLeaf: false, isAbstract: false) (isActive: false) (isIndirectlyInstantiated: true)}, targetElements = {e = org.eclipse.emf.ecore.impl.DynamicEObjectImpl@142708b (eClass: org.eclipse.emf.ecore.impl.EClassImpl@13d8d75 (name: Error) (instanceClassName: null) (abstract: false, interface: false)), el = org.eclipse.emf.ecore.impl.DynamicEObjectImpl@ead518 (eClass: org.eclipse.emf.ecore.impl.EClassImpl@15a4590 (name: Exponential) (instanceClassName: null) (abstract: false, interface: false)), c = org.eclipse.emf.ecore.impl.DynamicEObjectImpl@14c4636 (eClass: org.eclipse.emf.ecore.impl.EClassImpl@1a079fe (name: Component) (instanceClassName: null) (abstract: false, interface: false)), fge = org.eclipse.emf.ecore.impl.DynamicEObjectImpl@9585f1 (eClass: org.eclipse.emf.ecore.impl.EClassImpl@115142a (name: FaultsGenerateErrors) (instanceClassName: null) (abstract: false, interface: false)), ft = org.eclipse.emf.ecore.impl.DynamicEObjectImpl@8cbb92 (eClass: org.eclipse.emf.ecore.impl.EClassImpl@26bab (name: InternalFault) (instanceClassName: null) (abstract: false, interface: false)), fo = org.eclipse.emf.ecore.impl.DynamicEObjectImpl@16e9aa2 (eClass: org.eclipse.emf.ecore.impl.EClassImpl@15a4590 (name: Exponential) (instanceClassName: null) (abstract: false, interface: false))}, variables = {}}, sfh=IN!ComponentA, c=OUT!<unnamed>, fo=OUT!<unnamed>, el=OUT!<unnamed>, ft=OUT!<unnamed>, e=OUT!<unnamed>, fge=OUT!<unnamed>
at __exec__#18(chess2dim.atl)
local variables: self=chess2dim : ASMModule, e=TransientLink {rule = StatefulHardware2DIMComponent, sourceElements = {sfh = org.eclipse.uml2.uml.internal.impl.ComponentImpl@1946e0c (name: ComponentA, visibility: <unset>) (isLeaf: false, isAbstract: false) (isActive: false) (isIndirectlyInstantiated: true)}, targetElements = {e = org.eclipse.emf.ecore.impl.DynamicEObjectImpl@142708b (eClass: org.eclipse.emf.ecore.impl.EClassImpl@13d8d75 (name: Error) (instanceClassName: null) (abstract: false, interface: false)), el = org.eclipse.emf.ecore.impl.DynamicEObjectImpl@ead518 (eClass: org.eclipse.emf.ecore.impl.EClassImpl@15a4590 (name: Exponential) (instanceClassName: null) (abstract: false, interface: false)), c = org.eclipse.emf.ecore.impl.DynamicEObjectImpl@14c4636 (eClass: org.eclipse.emf.ecore.impl.EClassImpl@1a079fe (name: Component) (instanceClassName: null) (abstract: false, interface: false)), fge = org.eclipse.emf.ecore.impl.DynamicEObjectImpl@9585f1 (eClass: org.eclipse.emf.ecore.impl.EClassImpl@115142a (name: FaultsGenerateErrors) (instanceClassName: null) (abstract: false, interface: false)), ft = org.eclipse.emf.ecore.impl.DynamicEObjectImpl@8cbb92 (eClass: org.eclipse.emf.ecore.impl.EClassImpl@26bab (name: InternalFault) (instanceClassName: null) (abstract: false, interface: false)), fo = org.eclipse.emf.ecore.impl.DynamicEObjectImpl@16e9aa2 (eClass: org.eclipse.emf.ecore.impl.EClassImpl@15a4590 (name: Exponential) (instanceClassName: null) (abstract: false, interface: false))}, variables = {}}
at main#24(chess2dim.atl)
[Updated on: Mon, 31 January 2011 06:37] by Moderator
Current Time: Sun Jul 20 17:47:23 EDT 2025
Powered by FUDForum. Page generated in 0.02926 seconds
