Home » Modeling » TMF (Xtext) » AbstractXtextTests in 2.0
AbstractXtextTests in 2.0 [message #650887] Wed, 26 January 2011 22:09 Go to next message
how is the Validator used in Xtext 2.0 AbstractXtextTest ?
There is an extra parameter EValidatorRegistrar and I tried a wild guess
how it was supposed to be used.
In my setUp I now have:
with(MyStandaloneSetup.class);
// TODO: Xtext 2.0 - is the below ok ? (registrar is new parameter).
PPJavaValidator validator = get(MyJavaValidator.class);
EValidatorRegistrar registrar = get(EValidatorRegistrar.class);
tester = new ValidatorTester<MyJavaValidator>(validator, registrar);
Is this the correct way to get the EValidatorRegistrar?
I was able to call the validator, but I have lots of errors from failing
serialization, and problems with unresolved proxies - probably not
related to the ValidatorTester, but best to ask...
The editor parses and produces the model ok, but not when run using the
AbstractXtextTest. Is there some registration of my (external model)
that may be missing and that is done differently in 2.0 ?
- henrik
Re: AbstractXtextTests in 2.0 [message #650931 is a reply to message #650887] Thu, 27 January 2011 03:00 Go to previous messageGo to next message
Hi Henrik,
that's the right way to initialize the validator tester. It ensures,
that the global EMF registries will not be messed up after on test
execution.
Are you sure that your standalone setup registeres all the necessary
metamodels and resource factories?
Sebastian
Am 27.01.11 04:09, schrieb Henrik Lindberg:
> Regards
> - henrik
Re: AbstractXtextTests in 2.0 [message #650960 is a reply to message #650931] Thu, 27 January 2011 05:18 Go to previous messageGo to next message
I did not change anything in the standalone setup from the working setup
for Xtext 1.0. Will investigate...
- henrik
On 1/27/11 9:00 AM, Sebastian Zarnekow wrote:
> Hi Henrik,
> execution.
> Regards,
> Sebastian
Re: AbstractXtextTests in 2.0 [message #651080 is a reply to message #650960] Thu, 27 January 2011 12:04 Go to previous messageGo to next message
First part of the problem was a red herring - it was a toasted launch
config for the tests... - it now finds models as it is supposed to.
I do however not get calls to MyJavaValidator when running the tests
(works in the IDE and in 1.0). (I checked with the debugger, I can't say
I understand the data that is passed around when it is performing
validation, but the MyJavaValidator is included.
Do I need to make some specific declarations when running the tests?
Basically, the MyJavaValidator has a bunch of @Check methods for model
elements in the imported "MyModel" - in 1.0 it was enough to return the
MyPackage.eInstance from getPackages() (in 2.0, the imported package was
already registered by the super class so I added a check to not add it
twice).
Hints what to check next?
- henrik
> - henrik
>> Hi Henrik,
>> execution.
>> Regards,
>> Sebastian
Re: AbstractXtextTests in 2.0 [message #651081 is a reply to message #651080] Thu, 27 January 2011 12:12 Go to previous messageGo to next message
Hi Henrik,
does it make a differnce if your return a different result from
AbstractDeclarativeValidator#isLanguageSpecific?
Sebastian
Am 27.01.11 18:04, schrieb Henrik Lindberg:
> twice).
> - henrik
>> - henrik
>>> Hi Henrik,
>>> execution.
>>> Regards,
>>> Sebastian
Re: AbstractXtextTests in 2.0 [message #651088 is a reply to message #651081] Thu, 27 January 2011 12:19 Go to previous messageGo to next message
Yes !!
The super class method returns true, setting it to false makes it work.
Should I just override it or do something else?
It makes sense that the validator does not know that this is "My"
language as it was only fed a String. I guess the correct thing would be
to somehow indicate what language the string is supposed to be...
- henrik
On 1/27/11 6:12 PM, Sebastian Zarnekow wrote:
> Hi Henrik,
> Regards,
> Sebastian
Re: AbstractXtextTests in 2.0 [message #651094 is a reply to message #651088] Thu, 27 January 2011 12:37 Go to previous messageGo to next message
Hi Henrik,
the validator will try to determine the language from the resource of
the object by means of XtextResource#getLanguageName. Could you please
investigate why it fails in your case and file a ticket with your findings?
Sebastian
Am 27.01.11 18:19, schrieb Henrik Lindberg:
> Yes !!
> - henrik
>> Hi Henrik,
>> Regards,
>> Sebastian
Re: AbstractXtextTests in 2.0 [message #651124 is a reply to message #651094] Thu, 27 January 2011 16:33 Go to previous messageGo to next message
The key
org.eclipse.xtext.validation.AbstractInjectableValidator.cur rentLanguageName
does not get a value in the context.
Is this perhaps because I am only creating some model objects and then
calling the validator without having the model in a resource?
Basically like it is shown in the documentation:
public void testError2() {
FooElement model = MyLanguageFactory.eINSTANCE.createFooElement()
model.setBarAttribute("barbarbarbarfoo");
tester.validate(model).assertError(101);
- henrik
On 1/27/11 6:37 PM, Sebastian Zarnekow wrote:
> Hi Henrik,
> Regards,
> Sebastian
Re: AbstractXtextTests in 2.0 [message #651131 is a reply to message #651124] Thu, 27 January 2011 16:44 Go to previous message
Logged https://bugs.eclipse.org/bugs/show_bug.cgi?id=335624
- henrik
On 1/27/11 10:33 PM, Henrik Lindberg wrote:
> The key
> - henrik
>> Hi Henrik,
>> findings?
>> Regards,
>> Sebastian
Previous Topic:Left recursion
Next Topic:NamesAreUniqueValidationHelper ALWAYS using SimpleAttributeResolver.NAME_RESOLVER
Current Time: Sat Jul 19 19:57:40 EDT 2025
Powered by FUDForum. Page generated in 1.08708 seconds
