Home » Eclipse Projects » Eclipse Platform » Checking if a project was selected(Showing a popup menu entry only if a project is selected)
Checking if a project was selected [message #650725] Wed, 26 January 2011 04:42 Go to next message
Hi, I want to show a contribution to the popup menu of, for example, the package explorer only if a project is selected. This can be any project, not only a java project.
How can I do this? There seems to be no common superclass for projects.
For example, JavaProject only inherits from IAdaptable, but all other entries in the package explorer do the same, so I cannot make a distinction based on this class. How can I check (in an extension, i.e. plugin.xml) if the selection is any kind of project.
Thank you in advance for your hepl
Re: Checking if a project was selected [message #650762 is a reply to message #650725] Wed, 26 January 2011 07:48 Go to previous message
IProject is the project class to check for. You also need to adapt
before you check, that will convert entries like IJavaProject.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Previous Topic: failed oracle connection - not a valid base URI
Next Topic:File opened in two edtiors.
Current Time: Sat Jul 19 18:21:19 EDT 2025
Powered by FUDForum. Page generated in 0.04252 seconds
