Home » Modeling » Epsilon » [Patch] Exclude /org.eclipse.epsilon.workflow/bin from runtime Eclipse application classpath(Minor bugfix for a regression in the Ant tasks when running Epsilon from source in Eclipse Helios)
[Patch] Exclude /org.eclipse.epsilon.workflow/bin from runtime Eclipse application classpath [message #638104] Tue, 09 November 2010 17:48 Go to next message
Hi everyone,
Today, I decided to (finally!) upgrade to Helios my 3-workspace setup for Epsilon. I like to stay on the bleeding edge, so I keep a workspace with the latest revision of the Epsilon source code. From there, I run a second workspace with my metamodels, which hosts a third workspace where I try out the editors.
I noticed that my Ant tasks were not working anymore in this setup (they did just fine in Eclipse Galileo), but they worked if I installed Epsilon from its update site or the Marketplace. After some debugging, I found out that the classloader used to load the LoadModel Ant task was different from the Ant classloader. After pulling out some hairs over the rest of the day, I stumbled over this page:
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/ant_contributing_task.htm
I checked the various guidelines and surely enough, the org.eclipse.epsilon.workflow project did not have its bin/ output folder excluded from the runtime classpath while running runtime Eclipse applications. I just had to uncheck the folder in the "Plugin Development -> Runtime Classpath" page of the project's properties, and everything works like a charm again.
In case you're interested, I have pasted an equivalent patch at the end of this message. It's quite trivial, so I didn't think it would merit a proper bug report. If you need it anyway, just ask Smile.
Antonio
diff --git a/plugins/org.eclipse.epsilon.workflow/.settings/org.eclipse.pde.core.prefs b/plugins/org.eclipse.epsilon.workflow/.settings/org.eclipse.pde.core.prefs
index 344553d..b0e7d06 100644
--- a/plugins/org.eclipse.epsilon.workflow/.settings/org.eclipse.pde.core.prefs
+++ b/plugins/org.eclipse.epsilon.workflow/.settings/org.eclipse.pde.core.prefs
@@ -1,3 +1,4 @@
-#Wed Feb 21 12:24:26 GMT 2007
-eclipse.preferences.version=1
-resolve.requirebundle=false
+#Tue Nov 09 23:26:41 CET 2010
+eclipse.preferences.version=1
+resolve.requirebundle=false
+selfhosting.binExcludes=/org.eclipse.epsilon.workflow/bin
[Updated on: Tue, 09 November 2010 17:48] by Moderator
Re: [Patch] Exclude /org.eclipse.epsilon.workflow/bin from runtime Eclipse application classpath [message #638186 is a reply to message #638104] Wed, 10 November 2010 04:57 Go to previous messageGo to next message
Hi Antonio,
Many thanks for investigating and letting us know! We'll apply this
patch and commit to the SVN shortly.
Dimitris
Antonio García wrote:
> Hi everyone,
> Development -> Runtime Classpth" page of the project's properties, and
> proper bug report. If you need it anyway, just ask :).
> Cheers,
> Antonio
> diff --git
> a/plugins/org.eclipse.epsilon.workflow/.settings/org.eclipse .pde.core.prefs
> b/plugins/org.eclipse.epsilon.workflow/.settings/org.eclipse .pde.core.prefs
> @@ -1,3 +1,4 @@
Re: [Patch] Exclude /org.eclipse.epsilon.workflow/bin from runtime Eclipse application classpath [message #650717 is a reply to message #638186] Wed, 26 January 2011 04:05 Go to previous messageGo to next message
Hi Dimitrios,
I just updated my Git mirror to the latest revision in SVN trunk (1230) and it did not include the patch yet. Was there any problem with the patch?
If possible, I'd like to have it integrated, so I could drop my local patch at [1] and use the SVN version as is. I like to stay as close as possible to SVN.
[1]: http://goo.gl/4nuI9
Antonio
Re: [Patch] Exclude /org.eclipse.epsilon.workflow/bin from runtime Eclipse application classpath [message #650859 is a reply to message #650717] Wed, 26 January 2011 17:25 Go to previous messageGo to next message
Hi Antonio,
This slipped my attention. I'm sorry about that. I've now removed /bin from the classpath and committed the changes to the SVN.
Dimitris
Re: [Patch] Exclude /org.eclipse.epsilon.workflow/bin from runtime Eclipse application classpath [message #657986 is a reply to message #638104] Fri, 04 March 2011 14:38 Go to previous messageGo to next message
Hi Antonio, Dimitris,
Thanks for fixing this! I've just stumbled onto this bug too, and an update from SVN fixed the problem.
I thought it was worth adding that, on my machine at least, the problem was confusingly reported as a NullPointerException in EpsilonTask#getProjectRepository(). Calls to getProject() from EpsilonTask were returning null.
Louis.
Re: [Patch] Exclude /org.eclipse.epsilon.workflow/bin from runtime Eclipse application classpath [message #661616 is a reply to message #657986] Fri, 25 March 2011 11:07 Go to previous message
Hi Louis,
I am sorry to report that I still seem to be having problems with this.
I have updated from SVN, but when I try to run a workflow, I get the
following error trace:
> !SESSION 2011-03-25 15:03:16.659
> eclipse.buildId=M20110210-1200 java.version=1.6.0_22 java.vendor=Sun
> Microsystems Inc. BootLoader constants: OS=win32, ARCH=x86, WS=win32,
> NL=en_GB Framework arguments: -product org.eclipse.platform.ide
> Command-line arguments: -product org.eclipse.platform.ide -data
> D:\workspaces\epsilon/../bla -dev
> file:D:/workspaces/epsilon/.metadata/.plugins/org.eclipse.pd e.core/bla/dev.properties
> -os win32 -ws win32 -arch x86 -consoleLog !ENTRY
> org.eclipse.ant.launching 4 0 2011-03-25 15:03:29.873 !MESSAGE Failure
> of Background Ant Build !STACK 1
> org.eclipse.core.runtime.CoreException:
> D:\workspaces\bla\foo\workflow\build.xml:50:
> java.lang.NullPointerException at
> org.eclipse.ant.core.AntRunner.handleInvocationTargetExcepti on(AntRunner.java:452)
> at org.eclipse.ant.core.AntRunner.run(AntRunner.java:384) at
> org.eclipse.ant.internal.launching.launchConfigurations.AntL aunchDelegate$1.run(AntLaunchDelegate.java:298)
> at java.lang.Thread.run(Unknown Source) Caused by:
> org.apache.tools.ant.dispatch.DispatchUtils.execute(Dispatch Utils.java:116)
> at org.apache.tools.ant.TaskAdapter.execute(TaskAdapter.java:15 4) at
> org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:288)
> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at
> sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at
> java.lang.reflect.Method.invoke(Unknown Source) at
> org.apache.tools.ant.dispatch.DispatchUtils.execute(Dispatch Utils.java:106)
> at org.apache.tools.ant.Task.perform(Task.java:348) at
> org.apache.tools.ant.Target.execute(Target.java:357) at
> org.apache.tools.ant.Target.performTasks(Target.java:385) at
> org.apache.tools.ant.Project.executeSortedTargets(Project.ja va:1337)
> at org.apache.tools.ant.Project.executeTarget(Project.java:1306 ) at
> org.apache.tools.ant.helper.DefaultExecutor.executeTargets(D efaultExecutor.java:41)
> at
> org.eclipse.ant.internal.core.ant.EclipseDefaultExecutor.exe cuteTargets(EclipseDefaultExecutor.java:32)
> at org.apache.tools.ant.Project.executeTargets(Project.java:118 9) at
> org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:662)
> at
> org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:495)
> org.eclipse.ant.core.AntRunner.run(AntRunner.java:378) ... 2 more
> Caused by: java.lang.NullPointerException at
> org.eclipse.epsilon.workflow.tasks.EpsilonTask.getProjectRep ository(EpsilonTask.java:86)
> at
> org.eclipse.epsilon.workflow.tasks.emf.LoadModel.executeImpl (LoadModel.java:39)
> at
> org.eclipse.epsilon.workflow.tasks.EpsilonTask.execute(Epsil onTask.java:40)
> ... 24 more
I actually seem to be getting this twice.
Any suggestions?
Steffen
> Cheers,
> Louis.
Previous Topic:[EVL] Hanging when Validate view open
Next Topic:[ETL] Accessing one output of a multiple "to's" transformation
Current Time: Sat Jul 19 12:03:25 EDT 2025
Powered by FUDForum. Page generated in 0.04159 seconds
