Home » Language IDEs » ServerTools (WTP) » JSP / XHTML pages open extremely slow
JSP / XHTML pages open extremely slow [message #650508] Tue, 25 January 2011 06:07 Go to next message
Hi!
I have problems opening JSP and XHTML files. When choosing a JSP file from the "Open ressource" dialog, I have to wait more than a minute (far more than a minute!) until the file is finally shown in the editor. The Eclipse process is really busy during that period of time and the program does not respond.
If I remember correctly the problem occurred when upgrading Eclipse from 3.5.1 to 3.6 and remains ever since. I also upgraded to Eclipse 3.6.1 with no effect.
Any ideas?
I tried out the latest Indio build yesterday and had no problems opening JSP files. Unfortunately Indigo is not stable enough to be used in production environment right now so upgrading is not an option at the moment.
[Updated on: Tue, 25 January 2011 06:08] by Moderator
Re: JSP / XHTML pages open extremely slow [message #650531 is a reply to message #650508] Tue, 25 January 2011 07:46 Go to previous messageGo to next message
How large are these files? 10 lines, 100 lines, 100000 lines?
Blue Skies,
~Ian
Re: JSP / XHTML pages open extremely slow [message #650543 is a reply to message #650531] Tue, 25 January 2011 08:39 Go to previous messageGo to next message
The issue seems to be unrelated to the file size.
I checked some combinations of JSP files and found out that opening the file is extremely slow as soon as I use a taglib. Opening a file containing the following line takes about one minute:
<%@ taglib prefix="bean" uri="http://struts.apache.org/tags-bean"%>
If I remove the line everything seems to be fine.
Re: JSP / XHTML pages open extremely slow [message #650549 is a reply to message #650543] Tue, 25 January 2011 08:52 Go to previous messageGo to next message
I did a quick search around https://bugs.eclipse.org and did not see anything that seemed like this issue. Thus my suggestion would be to open a new bug.
As always, be sure to provide as much detail as possible when reporting a bug. Also please report the bug number back here for documentation purposes.
You can use the following link to report a bug to the Source Editor team.
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=WTP%20So urce%20Editing
Blue Skies,
~Ian
Re: JSP / XHTML pages open extremely slow [message #650563 is a reply to message #650549] Tue, 25 January 2011 09:25 Go to previous messageGo to next message
Thanks Ian. I created a new bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=335314
Re: JSP / XHTML pages open extremely slow [message #650566 is a reply to message #650508] Tue, 25 January 2011 09:30 Go to previous messageGo to next message
I'm going to wager a guess that what you're seeing is a duplicate of https://bugs.eclipse.org/321602, which has been fixed in the latest service release of Helios and is fixed in Indigo as well. Comment 10 in Bug 321602 has some instructions on applying the feature patch. Hopefully this will address your issue.
Re: JSP / XHTML pages open extremely slow [message #650567 is a reply to message #650566] Tue, 25 January 2011 09:39 Go to previous messageGo to next message
Yes Smile
Thanks for the hint. Finally JSP editing is back to normal Smile. I'll close the issue.
Re: JSP / XHTML pages open extremely slow [message #651877 is a reply to message #650566] Tue, 01 February 2011 16:00 Go to previous messageGo to next message
Nick Sandonato wrote on Tue, 25 January 2011 09:30
Nick, do you have any clue when this service release is about to get released? (I've just downloaded Eclipse and it shows the same build ID as the installation I'm experiencing the bug in.)
Thanks for the patch hint, I haven't noticed it before, I'm on it! :)
Re: JSP / XHTML pages open extremely slow [message #651918 is a reply to message #651877] Tue, 01 February 2011 23:46 Go to previous messageGo to next message
The stated date is February 25th for SR2.
And Indigo milestones should be stable enough for most uses. If you ran into trouble with one, it's worth filing a bug report so it can be fixed by release.
Re: JSP / XHTML pages open extremely slow [message #651955 is a reply to message #651918] Wed, 02 February 2011 04:05 Go to previous message
Thanks Nitin, I've just downloaded it and I will check it out. :)
Previous Topic:Need help with TCP/IP monitor
Next Topic:Need help with instalaltion.
Current Time: Sat Jul 19 07:09:14 EDT 2025
Powered by FUDForum. Page generated in 0.08545 seconds
