Home » Modeling » TMF (Xtext) » syntatic predicates in Xtext 2.0
syntatic predicates in Xtext 2.0 [message #649539] |
Wed, 19 January 2011 10:53  |
Noticed the remark "syntatic predicates (partly implemented in Xtext
2.0)" by jan.koehnlein@itemis.de in another thread.
This looks very promising and may help me remove some of the kludges I
have in the grammar I am working on.
Is there some info somewhere - bugzilla - ? that describes what this
partial syntactic predicate support consists of?
- henrik
Re: syntatic predicates in Xtext 2.0 [message #649672 is a reply to message #649641] |
Thu, 20 January 2011 03:15   |
Hi Henrik,
yes, =>RuleCall is possible and =>name=ID as well as =>('else' foo=Bar
'zonk'|'baz'), too.
We do currently not support predicates in terminal rules and what will
never be possible is to use unordered groups as predicates.
Sebastian
Am 20.01.11 03:30, schrieb Henrik Lindberg:
> Looks promising!
> Is it possible to have => RuleCall ?
> In my case the 'else' is something like:
> ElseRule : LOWER_E LOWER_L LOWER_S LOWER_E ;
> terminal LOWER_E : 'e' ;
> // etc
> Can the result be assigned? i.e. if I want the equivalence of op =
> 'else' as well as direct the parser.
> - henrik
> On 1/19/11 8:36 PM, Sebastian Zarnekow wrote:
>> Hi Henrik,
>> taken from commit message
>> http://git.eclipse.org/c/tmf/org.eclipse.xtext.git/commit/?i d=1aef0084ea6a83a98b9d91c02ec967e5c5a9fdf8
>> Predicates can be defined in the Xtext grammar by means of the '=>'
>> keyword that prefixes the actual value that should be parsed, e.g.
>> IfExpression:
>> 'if' '(' condition=Expression ')'
>> then=Expression
>> ( =>'else' else=Expression )?;
>> will guide the parser to assign parse the 'else' eager and thereby
>> ensure that it will be part of the innermost if-expression.
>> Does that help?
>> Regards,
>> Sebastian
Re: syntatic predicates in Xtext 2.0 [message #650162 is a reply to message #649954] |
Fri, 21 January 2011 21:40   |
The problem I am facing is that terminals allow specification of NOT,
but data rules do not, and since my "terminals" are context sensitive I
have to use data rules. If I could instead use a fragment and directly
use it in a datatype rule, it would save me from having long lists
specifying the various sets of valid characters. (Long lists which I
have a strong suspicion is the source of some of the performance
problems I am having.
So, fragments seems perfect to overcome this problem.
As an example, let's say that SL_COMMENT is context sensitive.
It is easily specified as a terminal.
terminal SL_COMMENT '#' .* ('\r'? '\n') ;
Doing the same with a data rule is possible, but requires listing every
possible source character in the language (which is what I did). Here is
the start of that:
SL_COMMENT
: HASH
( ANY_DIGIT
| ANY_LETTER
| PUNCTUATION
| SP | TAB | NBSP
CR? // CR optional depending on file format
NL // NL optional because file may end with a SL comment
If I understood fragments correctly, I would be able to provide
something like
CommentedStatement : statement SL_COMMENT? ;
fragment SL_COMMENT '#' .* ('\r'? '\n') ;
Please let me know if there is some other way to achieve what I want, or
if I misunderstood the usefulness of fragments - if not I will post an
enhancement request. (I agree that they are not terribly useful if they
can only be used inside terminals or other fragments).
Another alternative is naturally to support NOT and ANY (.) in datatype
rules.
Support for semantic predicates, the above, and the ability to use
'\uxxxx' would make my life a lot easier.
- henrik
On 1/21/11 8:56 AM, Sebastian Zarnekow wrote:
> Henrik, Marc,
> they are currently not planned since we never faced the need for them.
> Please file a feature request with a sample terminal rule that cannot be
> expressed with the currently available abstractions.
> Sebastian
Re: syntatic predicates in Xtext 2.0 [message #650359 is a reply to message #650162] |
Mon, 24 January 2011 10:36   |
Added: https://bugs.eclipse.org/bugs/show_bug.cgi?id=335203
as Sebastian suggested.
- henrik
> the start of that:
> SL_COMMENT
> : HASH
> ( ANY_DIGIT
> | ANY_LETTER
> | PUNCTUATION
> | SP | TAB | NBSP
> something like
> rules.
> Regards
> - henrik
>> Henrik, Marc,
>> Thanks,
>> Sebastian
Re: syntatic predicates in Xtext 2.0 [message #650477 is a reply to message #650162] |
Tue, 25 January 2011 03:11  |
Hi Henrik,
as you already noticed, terminal fragments are already available. And
the good news is: unicode escapes are possible, too :-)
Sebastian
Am 22.01.11 03:40, schrieb Henrik Lindberg:
> the start of that:
> SL_COMMENT
> : HASH
> ( ANY_DIGIT
> | ANY_LETTER
> | PUNCTUATION
> | SP | TAB | NBSP
> something like
> rules.
> Regards
> - henrik
>> Henrik, Marc,
>> Thanks,
>> Sebastian
Current Time: Sat Jul 19 20:48:29 EDT 2025
Powered by FUDForum. Page generated in 0.25694 seconds
