Home » Modeling » TMF (Xtext) » Two different DSL and the workflow
Two different DSL and the workflow [message #650311] Mon, 24 January 2011 06:25 Go to next message
Hello everyblody.
I have create two dsl.
The first descibe "Rule" objecr in a file .metarepDSL
For example :
rule  rule1 {
	author jguidoux
	date 20/11/2011
	version v1
the other DSL use the declared rules in the other langagge.
the extension of this language is repoDSL
this is an example :
Repository test
import rules.*
Groupe g1 {
	rule rule1
With xtext, no problem, the content assist works. (I can find the reference to rule1)
But in the generator, when I run the workflow, I have this message :
[CODE][
1 error:
test.repoDSL - /home/jeremie/test/com.tocea.xtext.repositoryDSL.generator/s rc/model/test.repoDSL
6: Couldn't resolve reference to Rule 'rule1'.
java.lang.RuntimeException: Problems running workflow workflow.RepositoryDSLGenerator: Validation problems:
1 error:
/CODE]
the workflow can't find the reference to the other language.
these two file are in the same folser : 'src/model"
this is my workflow ::
module workflow.RepositoryDSLGenerator
import org.eclipse.emf.mwe.utils.*
var targetDir = "src-gen"
var fileEncoding = "UTF-8"
var modelPath = "src/model"
Workflow {
	bean = StandaloneSetup {
		registerGeneratedEPackage = "com.tocea.emf.metaRepository.model.metaRepository.MetaRepositoryPackage"
		registerGeneratedEPackage = "com.tocea.emf.metaRepository.model.repository.RepositoryPackage"
	component = org.eclipse.xtext.mwe.Reader {
	// lookup all resources on the classpath
	// useJavaClassPath = true
	// or define search scope explicitly
		path = modelPath
		// this class will be generated by the xtext generator
		register = com.tocea.xtext.RepositoryDSLStandaloneSetup {}
		load = {
			slot = "repository"
			type = "Repository"
	component = org.eclipse.xpand2.Generator {
		expand = "templates::Template::main FOR repository"
		outlet = {
			path = targetDir
		fileEncoding = fileEncoding
I hope it is possible to do that.
Jérémie
Re: Two different DSL and the workflow [message #650323 is a reply to message #650311] Mon, 24 January 2011 07:09 Go to previous messageGo to next message
in your workflow i can find
but i should find something similar rgarding the other dsl too Wink
~ Christian
Re: Two different DSL and the workflow [message #650329 is a reply to message #650323] Mon, 24 January 2011 07:28 Go to previous message
That's the solution Smile
Jérémie
Previous Topic:Slightly OT: Cleanup Problems view
Next Topic:syntatic predicates in Xtext 2.0
Current Time: Sat Jul 19 20:24:51 EDT 2025
Powered by FUDForum. Page generated in 2.57012 seconds
