Home » Eclipse Projects » Virgo » virgo-web-server-2.1.0.RELEASE/bin/dmk.sh: line 210: OTHER_ARGS+= -jmxport: command not found(cannot shutdown the virgo server when started specifying a different port number)
virgo-web-server-2.1.0.RELEASE/bin/dmk.sh: line 210: OTHER_ARGS+= -jmxport: command not found [message #649594] Wed, 19 January 2011 15:38 Go to next message
I started the virgo server "virgo-web-server-2.1.0.RELEASE.zip" using the following command :
./startup.sh -clean -jmxport 9877
When I try to shutdown the server using the following command I get this error:
-bash-3.00$ ./shutdown.sh -jmxport 9877
/nc/drciload/DRCiFramework/ch/virgo-web-server-2.1.0.RELEASE /bin/dmk.sh: line 210: OTHER_ARGS+= -jmxport: command not found
/nc/drciload/DRCiFramework/ch/virgo-web-server-2.1.0.RELEASE /bin/dmk.sh: line 210: OTHER_ARGS+= 9877: command not found
The Server could not be reached, it may already be stopped.
I am able to shutdown if I start the server using the default port without specifying the jmxport argument.
My environment is AIX 5.3.
Java version is :
-bash-3.00$ java -version
java version "1.6.0"
Java(TM) SE Runtime Environment (build pap6460sr9-20101125_01(SR9))
IBM J9 VM (build 2.4, JRE 1.6.0 IBM J9 2.4 AIX ppc64-64 jvmap6460sr9-20101124_69295 (JIT enabled, AOT enabled)
J9VM - 20101124_069295
JIT - r9_20101028_17488ifx2
GC - 20101027_AA)
JCL - 20101119_01
Re: virgo-web-server-2.1.0.RELEASE/bin/dmk.sh: line 210: OTHER_ARGS+= -jmxport: command not found [message #649688 is a reply to message #649594] Thu, 20 January 2011 05:33 Go to previous messageGo to next message
I just had a go at reproducing this and can't get it to fail. (Mac + Java 1.6.0_22) Is there any chance you could try this on a different Java implementation to narrow down the cause? I ask as we have had issues with the IBM vm before.
I'll try this on AIX later and see if that works (or fails as it may be). Can't do it now as the AIX box isn't responding, I'm sure it will wake up later.
Chris.
Re: virgo-web-server-2.1.0.RELEASE/bin/dmk.sh: line 210: OTHER_ARGS+= -jmxport: command not found [message #650085 is a reply to message #649594] Fri, 21 January 2011 11:48 Go to previous messageGo to next message
Seems the AIX box isn't available so I can't try it out, apologies. Do you have any ability to try it on a different JVM?
Chris.
Re: virgo-web-server-2.1.0.RELEASE/bin/dmk.sh: line 210: OTHER_ARGS+= -jmxport: command not found [message #650108 is a reply to message #650085] Fri, 21 January 2011 13:40 Go to previous message
we have try virgo 2.0 release in the aix box. we found that something wrong with the IMB JDK SR9 .please find our observations below
1. shutdown.sh won't take any arguments. (ex - immediate , jmxport ) we fixed that by editing the dmk.sh
2. when start up the server in the normal mode (without -clean) it gives an error. in sun sdk it will start as usual.
3. with the IMB JDK server shut down with an error as follows - this is a huge stack trace and this is a portion of it.
[2011-01-21 12:40:13.687] System Bundle Shutdown o.e.v.kernel.userregion.internal.equinox.KernelBundleClassLo ader Failure when clearing JDBC drivers for KernelBundleClassLoader: [bundle=com.springsource.javax.servlet.jsp.jstl_1.1.2] java.lang.NoSuchFieldException: writeDrivers
at java.lang.Class.getDeclaredFieldImpl(Native Method)
at java.lang.Class.getDeclaredField(Class.java:507)
at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelB undleClassLoader.clearJdbcDrivers(KernelBundleClassLoader.ja va:273)
at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelB undleClassLoader.close(KernelBundleClassLoader.java:261)
at org.eclipse.osgi.internal.loader.BundleLoader.close(BundleLo ader.java:317)
at org.eclipse.osgi.internal.loader.BundleLoader.closeBundleLoa der(BundleLoader.java:1249)
at org.eclipse.osgi.framework.internal.core.BundleHost.refresh( BundleHost.java:131)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.u nloadAllBundles(StartLevelManager.java:657)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:262)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.s hutdown(StartLevelManager.java:215)
at org.eclipse.osgi.framework.internal.core.InternalSystemBundl e.suspend(InternalSystemBundle.java:266)
at org.eclipse.osgi.framework.internal.core.Framework.shutdown( Framework.java:690)
at org.eclipse.osgi.framework.internal.core.Framework.close(Fra mework.java:588)
at org.eclipse.osgi.framework.internal.core.InternalSystemBundl e$1.run(InternalSystemBundle.java:243)
at java.lang.Thread.run(Thread.java:735)
it seems this is due to the IMB JDK becouse in the windows env also we are getting the same when pointed to IMB jdk. but with sun JDK this was fine.
Thanks for your turn over.
Previous Topic:Virgo and log4j
Next Topic:No source with remote repository
Current Time: Sun Jul 20 12:02:30 EDT 2025
Powered by FUDForum. Page generated in 0.03517 seconds
