Home » Modeling » TMF (Xtext) » Does xbase work?
Does xbase work? [message #514799] Tue, 16 February 2010 06:50 Go to next message
I found xbase in the cvs repository.
I wonder if that is a good example or if it is just
dead code. There is a file called
org.eclipse.xtext.xbase/src/org/eclipse/xtext/xbase/example. xbase_example
which has some errors in the xbase editor.
What's going wrong here?
Michael
Michael Scharf
Wind River Systems GmbH
http://www.WindRiver.com
http://MichaelScharf.blogspot.com/
Re: Does xbase work? [message #514820 is a reply to message #514799] Tue, 16 February 2010 08:12 Go to previous messageGo to next message
Hi Michael,
Xbase is currently under development and subject to frequent changes.
The example file does not reflect the latest version - it is used to
discuss different syntax variants internally and may be not in sync with
the actual code.
Sebastian
Am 16.02.10 17:43, schrieb Michael Scharf:
> Michael
Re: Does xbase work? [message #514871 is a reply to message #514820] Tue, 16 February 2010 18:25 Go to previous messageGo to next message
On 2010-02-16 18:44, Sebastian Zarnekow wrote:
> Hi Michael,
> the actual code.
One of the problems we found with xbase.Xpression is:
XFeatureCall returns XExpression :
XPrimaryExpression
({XFeatureCall.target=current} "." name=ID ('('(params+=XExpression (','params+=XExpression )*)?')')?)*
if you have
a.b.c.d.e
the expression tree is reversed (you can see this in the outline)
e
d
c
b
a
This makes it quite hard to write a scope provider.
Maybe there is a trick to use this tree to provide
a scope provider. But we could not figure out how
to create a scope provider for this and since
xbase has no scope providers at all we are still looking
for a solution.....
we rewrote the grammar to something like
{XFeature} target=XPrimaryExpression members+=XMember*
XMember returns XExpression:
{XMember} "." name=ID
| {XFunctionCall} "." name=ID '('(params+=XExpression (','params+=XExpression )*)?')'
| {XIndex} '[' params+=XExpression (','params+=XExpression )* ']'
It does not give us a tree but it puts the a.b.c.d.e in a list in
the right order....
Michael
Michael Scharf
Re: Does xbase work? [message #515047 is a reply to message #514871] Wed, 17 February 2010 04:56 Go to previous messageGo to next message
>> Hi Michael,
>> the actual code.
> XPrimaryExpression
> if you have
> a.b.c.d.e
> e
> d
> c
> b
> a
Why is it hard?
In order to link e, I'll have to find out about the type of the target
expression (which is a.b.c.d).
Sven
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : blog.efftinge.de
Re: Does xbase work? [message #649279 is a reply to message #514799] Tue, 18 January 2011 09:46 Go to previous messageGo to next message
I m trying to get Xbase running by checking out xtext.xbase and xtext.common.types form the cvs repository. But if i run the xbase mw2, i get rule errors ...
7689 [main] INFO  ipse.xtext.generator.LanguageConfig  - generating infrastructure for org.eclipse.xtext.xbase.Xpression with fragments : ImplicitRuntimeFragment, ImplicitUiFragment, GrammarAccessFragment, ParseTreeConstructorFragment, XtextAntlrGeneratorFragment, JavaBasedContentAssistFragment
error(211): ../org.eclipse.xtext.xbase/src-gen/org/eclipse/xtext/xbase/parser/antlr/internal/InternalXpression.g:92:1: [fatal] rule ruleXExpression has non-LL(*) decision due to recursive rule invocations reachable from alts 1,2,6.  Resolve by left-factoring or using syntactic predicates or using backtrack=true option.
warning(200): ../org.eclipse.xtext.xbase/src-gen/org/eclipse/xtext/xbase/parser/antlr/internal/InternalXpression.g:92:1: Decision can match input such as "'('" using multiple alternatives: 1, 2, 6
As a result, alternative(s) 2,6 were disabled for that input
warning(200): ../org.eclipse.xtext.xbase/src-gen/org/eclipse/xtext/xbase/parser/antlr/internal/InternalXpression.g:1864:2: Decision can match input such as "'else'" using multiple alternatives: 1, 2
As a result, alternative(s) 2 were disabled for that input
error(211): ../org.eclipse.xtext.xbase/src-gen/org/eclipse/xtext/xbase/parser/antlr/internal/InternalXpression.g:3025:1: [fatal] rule ruleXExpressionInRichString has non-LL(*) decision due to recursive rule invocations reachable from alts 1,2,5.  Resolve by left-factoring or using syntactic predicates or using backtrack=true option.
warning(200): ../org.eclipse.xtext.xbase/src-gen/org/eclipse/xtext/xbase/parser/antlr/internal/InternalXpression.g:3025:1: Decision can match input such as "'('" using multiple alternatives: 1, 2, 5
As a result, alternative(s) 2,5 were disabled for that input
How did you get the editor running? Can you give me a hint?
Best,
Dan
Re: Does xbase work? [message #649424 is a reply to message #649279] Wed, 19 January 2011 03:19 Go to previous message
Hi Dan,
are you sure that your meant the CVS repo? It's frozen since June 2010
because we migrated to git.
Please note that Xbase is still subject to change and clients should
currently use only with a good connection to the developers of Xtext ;-)
Sebastian
Am 18.01.11 15:46, schrieb Daniel S:
> error(211):
> ../org.eclipse.xtext.xbase/src-gen/org/eclipse/xtext/xbase/p arser/antlr/internal/InternalXpression.g:92:1:
> warning(200):
> warning(200):
> ../org.eclipse.xtext.xbase/src-gen/org/eclipse/xtext/xbase/p arser/antlr/internal/InternalXpression.g:1864:2:
> error(211):
> ../org.eclipse.xtext.xbase/src-gen/org/eclipse/xtext/xbase/p arser/antlr/internal/InternalXpression.g:3025:1:
> option.
> warning(200):
> Best,
> Dan
Previous Topic:Toggle comment and empty lines
Next Topic:How to get the string for the statement, not the classname for the implemenation
Current Time: Sun Jul 20 08:38:01 EDT 2025
Powered by FUDForum. Page generated in 0.26162 seconds
