Home » Eclipse Projects » Eclipse Platform » Platform.getBundle() returns NULL everytime
icon5.gif  Platform.getBundle() returns NULL everytime [message #648561] Thu, 13 January 2011 09:23 Go to next message
Hello all,
currently I want to access resources stored in one of my plugins. At first I wondered how this should work and then I found the solution with Platform.getBundle().
So I have a static main method in a workspace plugin project and the same should access the resources. But when I want to get my plugin/bundle with the method above NULL is returned. NULL is also returned for definetely installed plugins like "com.ibm.icu" etc., on which the workspace project is also dependent.
Code:
public class CMain {
		Bundle bundleTest = Platform.getBundle("com.ibm.icu"); // or all other bundles
		System.out.println(bundleTest.toString());
What am I doing wrong? Or is this even the right way to do so?
Thanks in advance and best regards
Tom
[Updated on: Thu, 13 January 2011 09:25] by Moderator
Re: Platform.getBundle() returns NULL everytime [message #648571 is a reply to message #648561] Thu, 13 January 2011 09:35 Go to previous messageGo to next message
> public static void main(String[] args) {
The OSGi framework must be running in order for Platform to work
(especially methods like getBundle(*)). i.e. run as an eclipse app.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Platform.getBundle() returns NULL everytime [message #648576 is a reply to message #648571] Thu, 13 January 2011 09:57 Go to previous messageGo to next message
Hey Paul,
thanks for your answer and suggestion. I'll test it.
And is there a way to access resources in a plugin with a workspace project and execution as a Java application?
Thanks and cheers,
Tom
Re: Platform.getBundle() returns NULL everytime [message #648622 is a reply to message #648576] Thu, 13 January 2011 12:19 Go to previous messageGo to next message
I'm not sure what you mean. Resources (as appropriate) can still be
kept with classes and loaded via the standard java loading mechanism,
like getClass().getResourceAsStream(*).
Running as a "java app" means running a bunch of jars. SWT and JFace
can be run as a bunch of java apps (OSGI bundles are valid java jars),
but thing that depend on core.runtime and Platform cannot exist without
running the OSGi framework.
What exactly are you trying to do (or how did you get in this scenario)?
If you are writing a plugin, simply use the OSGi Bundle.getEntry(*)
mechanism. Why do you think you need to run your bundle as a java app?
PW
Paul Webster
Re: Platform.getBundle() returns NULL everytime [message #649012 is a reply to message #648622] Mon, 17 January 2011 04:32 Go to previous message
Hey Paul,
sry I ment "eclipse app", not "java app". Sorry for the misunderstanding I also don't know why I have called it java app Smile
I have a workflow contained in an xPand project, which I want to deploy as a plugin, so that a future workspace project can use this workflow out of the plugin. And because of this use case it is not my aim to run this plugin as an eclipse app. That's why I asked for another way to access resources in a plugin.
I'll read something about getClass().getResourceAsStream(*) and Bundle.getEntry(*) and put a feedback here. Thanks for your help!
Bye Tom Smile
Previous Topic:How to have a fragment project replace a directory of files
Next Topic:Relaunching Debugger with Project Variables
Current Time: Sat Jul 19 12:12:10 EDT 2025
Powered by FUDForum. Page generated in 0.03696 seconds
