Existing remote project [message #648890] |
Fri, 14 January 2011 19:05 |
I installed eclipse with PDT in order to accelerate the development of my project, which grew out of it's initial bounds.
The point is that i have a lot of files on remote server with related database. I need to work with this bunch of code directly on the server (downloading to local and publishing back is inappropriate for several reasons) , therefore i need to create an remote project that will contain all these files so that I can work with them in a reasonable way.
I've installed the Target Management (RSE) and managed to connect to the server via FTP, the files, however, are not aligned to any project as far as I feel it and therefore i cant make the best of the IDE (like code assistant etc).
I also couldnt find any sufficient tutorial that would describe this topic adequately, therefore i hope that someone here is capable of solving this issue.
I'm totaly new to eclipse and would appreciate any help given about the problem I'm coping with.
FUDForum. Page generated in 0.04349 seconds
