Home » Modeling » EMF » [EMF/Genmodel] Filtering right instances in generated editor
[EMF/Genmodel] Filtering right instances in generated editor [message #648487] Thu, 13 January 2011 02:53 Go to next message
In EMF I modeled some metamodel of a data model. M y classes are: Table, KeyColumn and ExportLink. Table  class has KeyColumns and ExportLink has KeyColumns  as well.  But ExportLink should have only instances of Table's KeyColumns. My problem is filtering Table's K eyColumns in generated editor. Multiline popup is populated by KeyColumn instances belonging to all Table instances and I am not able to filter th em efficiently.
My questions are:
1. What is the best (modeling or configuring) practice to solve this problem?
2. How can I simply transform my existing model instances in case of bad metamodel?
Vladimir
[Updated on: Thu, 13 January 2011 02:56] by Moderator
Re: [EMF/Genmodel] Filtering right instances in generated editor [message #648631 is a reply to message #648487] Thu, 13 January 2011 12:39 Go to previous messageGo to next message
--------------010302050201080803030700
Vladimir,
Check out this FAQ:
2.46 How can I control which instances are available as choices when
editing a property in the properties view?
< http://wiki.eclipse.org/index.php/EMF/FAQ#How_can_I_control_ which_instances_are_available_as_choices_when_editing_a_prop erty_in_the_properties_view.3F>
You'll want to define a named constraint that flags invalid choices as
an error so the user can be informed and can use the editor to fix it.
Generally all this involved writing code.
> My questions are:
> problem?
> 2. How will I simply transform my existing model instances in case of
> bad metamodel?
> Vladimir
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Vladimir,<br>
<br>
Check out this FAQ:<br>
<blockquote><a
href=" http://wiki.eclipse.org/index.php/EMF/FAQ#How_can_I_control_ which_instances_are_available_as_choices_when_editing_a_prop erty_in_the_properties_view.3F"><span
class="tocnumber">2.46</span> <span class="toctext">How can I control
which instances are available as choices when editing a property in the
properties view?</span></a><br>
</blockquote>
an error so the user can be informed and can use the editor to fix it.<br>
<br>
Generally all this involved writing code.<br>
<br>
<br>
Vladimir wrote:
<blockquote cite="mid:igmao2$h0s$1@news.eclipse.org" type="cite"> In EMF I modeled some metamodel of a data model. M
<br>
<br>
My questions are:
<br>
problem?
<br>
bad metamodel?
<br>
<br>
<br>
Vladimir
<br>
</blockquote>
</body>
</html>
--------------010302050201080803030700--
Re: [EMF/Genmodel] Filtering right instances in generated editor [message #648749 is a reply to message #648631] Fri, 14 January 2011 07:07 Go to previous messageGo to next message
Ed,
thanks for the link. I am convinced that linked solution is the right one I need. In the meantime I looked around and I found support for Feature Setting Delegates in Helios. Please see http:// wiki.eclipse.org/EMF/New_and_Noteworthy/Helios#Support_for_F eature_Setting_Delegates.
It is completely generated solution based on OCL constraints. But my first attempt to implement it ended with confusing exception:
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.ocl.ecore.delegate.OCLDelegateException: Missing or invalid derivation constraint for 'SqlModel::ExportLink.exportedKeys'
I simply added annotation with constraint on exportedKeys reference. I was pleased that only model code was regenerated. But OCL constraint is generated in a comment.
Do you agree with me that setting delegates can be used for filtering? Did I misunderstand anything in implementation?
Vladimir
Re: [EMF/Genmodel] Filtering right instances in generated editor [message #648755 is a reply to message #648749] Fri, 14 January 2011 07:41 Go to previous messageGo to next message
Sorry, I oversaw generated OCL constraints in the code:
	protected void createOrgAnnotations() {
		String source = "org.eclipse.ocl.ecore.OCL";
		addAnnotation
		  (getExportLink_ExportedKeys(),
		   source,
		   new String[] {
			 "derivation", "if (self.relationship.master.oclIsUndefined()) then OrderedSet{} else self.relationship.master.keyColumns->asOrderedSet() endif"
		addAnnotation
		  (getExportLink_ExportedFields(),
		   source,
		   new String[] {
			 "derivation", "if (self.relationship.master.oclIsUndefined()) then OrderedSet{} else self.relationship.master.columns->asOrderedSet() endif"
		addAnnotation
		  (getImportLink_ForeignKeys(),
		   source,
		   new String[] {
			 "derivation", "if (self.relationship.detail.oclIsUndefined()) then OrderedSet{} else self.relationship.detail.keyColumns->asOrderedSet() endif"
		addAnnotation
		  (getImportLink_ForeignFields(),
		   source,
		   new String[] {
			 "derivation", "if (self.relationship.detail.oclIsUndefined()) then OrderedSet{} else self.relationship.detail.columns->asOrderedSet() endif"
Re: [EMF/Genmodel] Filtering right instances in generated editor [message #648801 is a reply to message #648755] Fri, 14 January 2011 09:53 Go to previous messageGo to next message
So, for now I returned to the solution recommended by Ed. It definitely works for me. Instead of the OCL expression:
    OrderedSet{}
else
endif
I wrote following code:
public Collection<?> getChoiceOfValues(Object object) {
    List<Object> choiceOfValues = new ArrayList<Object>();
    // Filter the choices before returning them
    if (object instanceof ExportLinkImpl) {
        ExportLinkImpl exportLinkImpl = (ExportLinkImpl) object;
        TableImpl master = (TableImpl) ((RelationshipImpl) exportLinkImpl.eContainer()).getMaster();
        if (master != null) {
            choiceOfValues.addAll(master.getKeyColumns());
    return choiceOfValues;
Re: [EMF/Genmodel] Filtering right instances in generated editor [message #648823 is a reply to message #648749] Fri, 14 January 2011 11:17 Go to previous messageGo to next message
Vladimdir,
I'm not sure I understand how you'd expect to use it for filtering; the
property descriptors search the whole instance for valid candidates
(objects of the right type), so I don't see how any form of setting
delegate would impact that search. You might use OCL to implement a
constraint...
Vladimir wrote:
> Ed,
> http://wiki.eclipse.org/EMF/New_and_Noteworthy/Helios#Suppor t_for_Feature_Setting_Delegates
> !STACK 0
> Vladimir
Re: [EMF/Genmodel] Filtering right instances in generated editor [message #648824 is a reply to message #648801] Fri, 14 January 2011 11:19 Go to previous messageGo to next message
Vlad,
Comments below.
> OrderedSet{}
> else
> endif
> @Override
I've asked many people this same question yet no one ever answers it:
What compels you to use the Impl classes rather than the interfaces when
casting? The reason I ask is because we never show examples like this.
Worst of all, there's no reason to expect that every instance of
ExportLink will necessarily be implemented by ExportLinkImpl. In fact,
with multiple inheritance, that generally won't be something you can or
should expect...
Re: [EMF/Genmodel] Filtering right instances in generated editor [message #648846 is a reply to message #648824] Fri, 14 January 2011 12:33 Go to previous messageGo to next message
casting?
What compels me? Desperation? Smile
No, seriously: that snippet was only very working version. I've already corrected it. Don't crucify me Smile
Re: [EMF/Genmodel] Filtering right instances in generated editor [message #648851 is a reply to message #648823] Fri, 14 January 2011 12:52 Go to previous message
> constraint...
Ed,
that was only an idea, rather my wish. If you type something like that
"self.relationship.master.keyColumns->asOrderedSet()"
in interactive OCL console, you get right collection, not constraint. It would be nice if OCL expression could supersede a relation. Maybe an operation instead of a relation is better for such feature.
Vladimir
[Updated on: Fri, 14 January 2011 12:56] by Moderator
Re: [EMF/Genmodel] Filtering right instances in generated editor [message #648853 is a reply to message #648846] Fri, 14 January 2011 12:43 Go to previous message
Vladimir,
Sorry, I don't mean to insult you. I just wonder why I see it so
often. There are two obvious choices for casting. Cast to the
interface or cast to the implementation class. I would expect the
latter to be an uncompelling choice (the name isn't so pretty) so I
wonder why folks make the choice so often. I'm just very curious. I
imagine if the bundle didn't export the impl package folks wouldn't make
that mistake (but then their model wouldn't be extensible).
> casting?
> What compels me? Desperation? :)
> already corrected it. Don't crucify me :)
Previous Topic:[EMF Compare] Extending UI
Next Topic:[CDO] [Config] DataSource not properly initialized
Current Time: Sun Jul 20 14:56:21 EDT 2025
Powered by FUDForum. Page generated in 0.55188 seconds
