Home » Archived » B3 » Google guice dependency not present on the b3 developer guide page
Google guice dependency not present on the b3 developer guide page [message #648713] Fri, 14 January 2011 03:06 Go to next message
I tried setting up b3 to run the tests on it, but I have errors in the workspace because it doesn't find google guice.
From which update site should I take it?
http://wiki.eclipse.org/Eclipse_b3/contributing/Setting_Up_D evelopment_Environment
Thanks.
Re: Google guice dependency not present on the b3 developer guide page [message #648774 is a reply to message #648713] Fri, 14 January 2011 08:45 Go to previous messageGo to next message
I think it is enough to get xtext from the Helios repo - that should
include everything except the antlr generator (which is needed if you
want to re-generate from the grammar (which is not required to just
build and run b3). You get the antlr generator from the itemis update site).
- henrik
> Thanks.
Re: Google guice dependency not present on the b3 developer guide page [message #648781 is a reply to message #648774] Fri, 14 January 2011 08:57 Go to previous messageGo to next message
Upps. I installed only Xtext (not the SDK).
Thanks for the reply.
Re: Google guice dependency not present on the b3 developer guide page [message #652282 is a reply to message #648781] Thu, 03 February 2011 08:04 Go to previous message
Hi Fabian,
which Xtext feature did you install that came without guice? Xtext
runtime should include it.
Sebastian
Am 14.01.11 14:57, schrieb Fabian Baboschi:
Previous Topic:howto Update the Eclipse b3/aggregator/manual wiki
Next Topic:Cannot install b3 headless
Current Time: Sat Jul 19 19:47:58 EDT 2025
Powered by FUDForum. Page generated in 0.23939 seconds
