Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Compare] Epatch and NullPointerException
[EMF Compare] Epatch and NullPointerException [message #648484] Thu, 13 January 2011 02:25
Hy,
I'm using EMF Compare and I want to create a patch file from a EMF compare result.
I have this kind of error (It can be on doRemove or doAdd).
I hadn't found bug declared about it.
Does someone know this problem ?
Stef
at org.eclipse.emf.compare.epatch.diff.DiffEpatchService.doRemo ve(DiffEpatchService.java:156)
at org.eclipse.emf.compare.epatch.diff.DiffEpatchService.handle EleChangeLeft(DiffEpatchService.java:263)
at org.eclipse.emf.compare.epatch.diff.DiffEpatchService.conver t(DiffEpatchService.java:81)
at org.eclipse.emf.compare.epatch.diff.DiffEpatchService.create Epatch(DiffEpatchService.java:53)
at fr.macif.mega.xpdl.patch.action.MergeAction.exportSnapshot(M ergeAction.java:52)
at org.eclipse.emf.compare.ui.export.ExportMenu$2.run(ExportMen u.java:255)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:4066)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3657)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 38)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:664)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:115)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
Previous Topic: Problem: failed to create task or type emf.JETCompiler
Next Topic:[EMF Compare] Cannot open emfdiff file
Current Time: Sat Jul 19 20:05:20 EDT 2025
Powered by FUDForum. Page generated in 0.02399 seconds
