Home » Eclipse Projects » EGit / JGit » One repository per Eclipse project?
One repository per Eclipse project? [message #647811] Sun, 09 January 2011 10:28 Go to next message
I have 7 Eclipse projects, they are all plug-ins for the same
application. I use one CVS repository with 7 folders, one for each project.
I experimented with eGit. Now it wants to create a repository for each
project. 7 repositories? It doesn't seem possible to create one master
git repository and add 7 eclipse projects to it. When I do a
"Team->Share Project" I only get the option to create a new repository
under the project's root folder.
Am I missing something?
PB
Re: One repository per Eclipse project? [message #647924 is a reply to message #647811] Mon, 10 January 2011 08:34 Go to previous messageGo to next message
It seems to me that to add projects to an existing repo, you need to
create the project directory in the repo.
ex: I created a bare repo, and then cloned it locally. Then when I
created a project, I unchecked "use default location" and put the
project in a subdir in my local repo. Then when I share the project, it
finds the .git directory in the parent folder.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: One repository per Eclipse project? [message #647936 is a reply to message #647924] Mon, 10 January 2011 09:18 Go to previous message
> PW
Yes, thanks.
PB
Previous Topic:Installs but no sign of Egit
Next Topic:Idenifying a repository
Current Time: Sun Jul 20 14:09:32 EDT 2025
Powered by FUDForum. Page generated in 0.23009 seconds
