Custom editing widgets for properties of model elements [message #647422] |
Thu, 06 January 2011 03:38  |
Hello again,
it is possible to implement other widgets for editing properties of model elements??
E.g. when I click on the value filed of the property in the property view i want to open a text editor for comfortable editing. Are there any possibilities ?
Kind regards,
Patrick
Re: Custom editing widgets for properties of model elements [message #647501 is a reply to message #647454] |
Thu, 06 January 2011 12:08  |
--------------050408030306040605040906
That's right. This recipe shows how:
< http://wiki.eclipse.org/EMF/Recipes#Recipe:_Create_your_own_ property_editor_in_a_generated_application>
Christophe Bouhier wrote:
> On 06-01-11 09:38, Patrick Schmitt wrote:
>> Hello again,
>> model elements?? E.g. when I click on the value filed of the property in
> By default a PropertySource is created by the AdapterFactory which can
> be fed into a PropertyView. The AdapterFactory consults generated
> XXXItemProvider(s) and creates the PropertySource from
> PropertyDescriptors which you can find in your XXXItemProvider
> (Generated). The EStructuralFeature type and perhaps some other
> attributes would determine the chosen cell-editor, and this is what
> you need to overwrite. I think you need to customize the class
> PropertySource which is instantiated in the AdapterFactory. Follow the
> method getEditableValue(object) in PropertySource
> Cheers C.
>> Kind regards,
>> Patrick
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
That's right. This recipe shows how:<a
href=" http://wiki.eclipse.org/EMF/Recipes#Recipe:_Create_your_own_ property_editor_in_a_generated_application"><br>
</a>
<blockquote><a
href=" http://wiki.eclipse.org/EMF/Recipes#Recipe:_Create_your_own_ property_editor_in_a_generated_application"> http://wiki.eclipse.org/EMF/Recipes#Recipe:_Create_your_own_ property_editor_in_a_generated_application</a><br>
</blockquote>
<br>
<br>
<blockquote cite="mid:ig4fln$fh$1@news.eclipse.org" type="cite">On
<br>
<blockquote type="cite">Hello again,
<br>
<br>
in
<br>
<br>
<br>
<br>
</blockquote>
<br>
attributes would determine the chosen cell-editor, and this is what you
<br>
<br>
Cheers C.
<br>
<br>
<br>
<blockquote type="cite">Kind regards,
<br>
Patrick
<br>
</blockquote>
<br>
</blockquote>
</body>
</html>
--------------050408030306040605040906--
FUDForum. Page generated in 0.21756 seconds
