Home » Eclipse Projects » Eclipse Platform » Using org.eclipse.ui.console for my RCP -- problem: cant listen to return keys or alike
Using org.eclipse.ui.console for my RCP -- problem: cant listen to return keys or alike [message #647450] Thu, 06 January 2011 08:16 Go to next message
I am trying to use a console view in my RCp application. Since eclipse has this org.eclipse.ui.console implementations, I added a IOConsole to my workbench. It provides one InputStream to read from it, but I don't know how to be informed when actually there is a need to read from the console, specifically: when the return key was pressed. The only possibility seems to me to permanently read the input stream in a background thread, which seems not elegant to me, and unperformant.
Since there are zero tutorials or documentation further than the javadoc available, I am really stuck here. Can you help me, please?
Thanks!
Re: Using org.eclipse.ui.console for my RCP -- problem: cant listen to return keys or alike [message #647770 is a reply to message #647450] Sat, 08 January 2011 14:52 Go to previous message
Me again..
Solved it:
IOConsole.getDocument().addDocumentListener(...), combined with ioConsole.getInputStream.available();
Just watch out, it seems like there is a bug in the IOConsoleOutputStream implementation of available - it throws a IOException sometimes when calling available(), stating that the Stream is closed, even if that's not true. just catch and ignore until fix.
Previous Topic:how to set contents for different instances of the same view
Next Topic:where did the structure compare go?
Current Time: Sat Jul 19 22:52:00 EDT 2025
Powered by FUDForum. Page generated in 0.04252 seconds
