Home » Eclipse Projects » Standard Widget Toolkit (SWT) » TreeViewers, Editing support and multiple Selection
TreeViewers, Editing support and multiple Selection [message #647247] |
Wed, 05 January 2011 06:05  |
Hy everyone !
I have defined a Tree Editor, that allows multiple selection.
When I try to install an editing support on the ViewerColumn associated to this tree :
ViewerColumn treeColumn = treeViewer.getViewerColumn(0);
treeColumn.setEditingSupport(myTreeEditingSupport)
It breaks the multiple selection (I can still select multiple TreeItems, but there is a lot of graphical bugs, and I cannot always see the TreeItems I have selected).
According to this post :
http://forums.dzone.com/eclipse/1463-multi-row-selection-tab leviewer-editing-support.html
it is impossible to set an Editing Support and keep mutliple selections capabilities.
I wondered if anyone had encountered this issue, and has a work around or a good solution to give.
Thanks by advance,
Alex
Re: TreeViewers, Editing support and multiple Selection [message #647355 is a reply to message #647247] |
Wed, 05 January 2011 13:30   |
I'm doing something quite different.
First I don't use TreeViewer (don't ask me why : ), but directly a Tree.
Second, I don't put Text fields in the TreeEditor to edit text, but I use TreeEditor, and put Button and CCombo inside. And I don't create them when user click on tree item, there created at tree item initialization.
Anyway, I suppose TreeViewer use TreeEditor and Text to perform editing, as this the way to do that thing.
I had some bug to fix, one of them was related to item selection like you.
I had to put some listener on my Button and the tree, this one :
button.addSelectionListener(new SelectionListener() {
public void widgetDefaultSelected(SelectionEvent dummy) {
public void widgetSelected(SelectionEvent event) {
// have to manually select the underlining treeItem
tree.forceFocus(); // on window, item will be grayed instead of blue without this
if(mouseOnCheckBox[0]) {
// I deals with check box buttons, in my case user clicked just on the box, not on the text of the button
// so don't want to select the item, just do the action
doSomething();
return;
// user clicked on icon or text
button.setSelection(!button.getSelection()); // ugly hack thing I have to do with my stupid check buttons
// now I have to select the item, to be better, I have to handle CTRL or SHIFT key
if((event.stateMask & SWT.SHIFT) == 0) {
if((event.stateMask & SWT.MOD1) == 0)
tree.deselectAll(); // user have no special key pressed
} else if(tree.getSelection().length > 0) { // shift key : select items between last selection and current
TreeItem treeItems[] = tree.getSelection();
// It is a bug : I don't know how to retrieve the last selected item, I take the last in the list but it's wrong.
TreeItem lastSelectedItem = treeItems[treeItems.length-1];
// all my tree item got there data field set to an object, that allows to retrieve her index
// I have to use virtual tree since TreeEditor and Button or CCombo create too much kernel object...
if(getAbstractItem(lastSelectedItem) != null) {
int index = getAbstractItem(lastSelectedItem).getIndex();
int index2 = getAbstractItem(treeItem).getIndex();
if(index > index2) {
int swap = index;
index = index2; index2 = swap;
// in fact, I just retrieve the range of item to select, when user have Shift key pressed
for(; index <= index2; index++)
tree.select(tree.getItem(index));
return;
if((event.stateMask & SWT.MOD1) != 0 && isSelected(treeItem)) // user clicked on ctrl or the item was already selected
tree.deselect(treeItem);
else
tree.select(treeItem);
that's for the selection when user click on your Text field.
As you can see, that's bad because I "recreate the wheel", and badder...
Now, we have to make the Text background follow the tree item background (white, blue or gray).
Here I use a simple tree listener :
// listener that set buttons background and foreground like tree items
tree.addListener(SWT.EraseItem, new Listener() {
public void handleEvent(Event event) {
if(event.index != 0)
return;
// retrieve the button associated whith the tree item
Button button = getButton(getAbstractItem((TreeItem)event.item));
if(button != null && !button.isDisposed()) {
button.setForeground(event.gc.getForeground());
button.setBackground(event.gc.getBackground());
There's still a bug under window : font color (getForeground()) don't follow. It stay black while it should goes white...
May be you can adapt this kind of work around to your treeViewer
[Updated on: Wed, 05 January 2011 14:58] by Moderator
Re: TreeViewers, Editing support and multiple Selection [message #647429 is a reply to message #647355] |
Thu, 06 January 2011 04:55  |
Thanks a lot for your fast reply.
I have found a solution very similar to yours :
1. I define a Listener with the following handleEvent method :
public void handleEvent(final Event event) {
event.detail &= ~SWT.HOT;
if ((event.detail & SWT.SELECTED) == 0)
return; /* item not selected */
final int clientWidth = treeViewer.getTree().getClientArea().width;
final GC gc = event.gc;
final Color oldBackground = gc.getBackground();
if (DTableEraseItemListener.IS_WINDOWS_OS) {
if (event.index == tableViewerManager.getActiveColumn()) {
// Make some tests to correct the the Windows problem.
if (lastSelectedLineDrawned != null && lastSelectedColumnDrawned != -1 && !lastSelectedLineDrawned.equals(event.item)
&& lastSelectedColumnDrawned == tableViewerManager.getActiveColumn()) {
gc.setBackground(DTableEraseItemListener.COLOR_LIST_OTHER_CELLS_SELECTED);
} else {
// Draw the background of the selected cell to another color
gc.setBackground(DTableEraseItemListener.COLOR_LIST_SELECTED);
lastSelectedLineDrawned = event.item;
lastSelectedColumnDrawned = tableViewerManager.getActiveColumn();
} else {
// Draw the background to selected for the other cells of the
// line of the selected cell
gc.fillRectangle(event.x, event.y, event.width, event.height);
} else {
if (tableViewerManager.getActiveColumn() == 0) {
// Draw the background to selected for all the cells of the line
gc.fillRectangle(0, event.y, clientWidth, event.height);
} else if (event.index == tableViewerManager.getActiveColumn()) {
} else {
// Reset to previous background
gc.setBackground(oldBackground);
event.detail &= ~SWT.SELECTED;
2. I add this listener to my TreeViewer
treeViewer.getTree().addListener(SWT.EraseItem, myListener);
Everything then works fine !
Thanks again, hope this post will help
Alex
Current Time: Sat Jul 19 06:21:31 EDT 2025
Powered by FUDForum. Page generated in 0.03303 seconds
