Home » Eclipse Projects » Marketplace Client Project » Can I use Marketplace Client to define what to install?
Can I use Marketplace Client to define what to install? [message #646411] Thu, 23 December 2010 15:06 Go to next message
I need an UI like marketplace-client, but I don't want to download the things I define, but want to store the definitions in my program and want to download it afterwards headlessly at once.
Is there a possibility to use parts of the client, perhaps the core? I looked at my eclipse-version. There isn't a src-jar available, I guess.
Can you give me hint, were the code is hosted or give me a tip, if my needs can be fulfilled with marketplace-client?
All in all I guess it's a really cool thing in addition to the updatesites
Thanks in advance
Best regards
Markus
Re: Can I use Marketplace Client to define what to install? [message #647096 is a reply to message #646411] Tue, 04 January 2011 10:37 Go to previous messageGo to next message
You might take a look at the discover connector code in the p2 project. MPC is based on this code but doesn't have the MPC UI.
Re: Can I use Marketplace Client to define what to install? [message #647188 is a reply to message #647096] Tue, 04 January 2011 17:03 Go to previous message
Thank you, I will try
Previous Topic:So what about true marketplace support...
Next Topic:Using org.eclipse.epp.internal.mpc.core.service.DefaultMarketplaceService behind a proxy
Current Time: Sat Jul 19 14:14:11 EDT 2025
Powered by FUDForum. Page generated in 0.03347 seconds
