Home » Language IDEs » Java Development Tools (JDT) » What does XX:MaxPermSize=690M mean in Eclipse.ini ?
What does XX:MaxPermSize=690M mean in Eclipse.ini ? [message #646327] Thu, 23 December 2010 06:22 Go to next message
In Eclipse.ini there is a parameter:
XX:MaxPermSize=690M
What exactly does it mean?
What are the best values?
Which errors do i get when the value is too low?
Are they dependent from the physical memory size?
Are they dependent from 32bit or 64bit version?
Ben
Re: What does XX:MaxPermSize=690M mean in Eclipse.ini ? [message #646357 is a reply to message #646327] Thu, 23 December 2010 08:24 Go to previous messageGo to next message
> XX:MaxPermSize=690M
> Ben
http://wiki.eclipse.org/FAQ_How_do_I_increase_the_permgen_si ze_available_to_Eclipse%3F
Re: What does XX:MaxPermSize=690M mean in Eclipse.ini ? [message #646993 is a reply to message #646357] Mon, 03 January 2011 17:09 Go to previous messageGo to next message
Ok, this page explains how to pass the variable to Eclipse/JVM.
but it does NOT explain what the meaning is and what are suitable arguments at all?
Does the optimal MaxPermSize depend from the avaiable Memory or 32bit/64bit or intended prgm allocations....
Ben
Re: What does XX:MaxPermSize=690M mean in Eclipse.ini ? [message #646998 is a reply to message #646993] Mon, 03 January 2011 17:14 Go to previous messageGo to next message
Mon, 03 Jan 2011 17:09:08 -0500, /Ben/:
> arguments at all?
I really like that one:
http://lmgtfy.com/?q=XX%3AMaxPermSize
Stanimir
Re: What does XX:MaxPermSize=690M mean in Eclipse.ini ? [message #647020 is a reply to message #646993] Mon, 03 January 2011 23:53 Go to previous messageGo to next message
> arguments at all?
> Ben
The second line there says: "PermGen is the permanent generation of
objects in the VM (Class names, internalized strings, objects that will
never get garbage-collected)"
What more do you need ?
Re: What does XX:MaxPermSize=690M mean in Eclipse.ini ? [message #647046 is a reply to message #647020] Tue, 04 January 2011 05:32 Go to previous messageGo to next message
So ok, what is the difference between specifying
--launcher.XXmaxPermSize
256m
and
-vmargs
-XX:MaxPermSize=690M
in eclipse.ini?
Re: What does XX:MaxPermSize=690M mean in Eclipse.ini ? [message #647052 is a reply to message #647046] Tue, 04 January 2011 06:06 Go to previous message
> 256m
> and
> -vmargs
> in eclipse.ini?
Are you sure that you read through
It very clearly states
"With the above arguments, if the VM being used is a Sun VM and there is
not already a -XX:MaxPermSize= VM argument, then the launcher will
automatically add -XX:MaxPermSize=256m to the list of VM arguments being
used. The 3.3 launcher is only capable of identifying Sun VMs on Windows.
The option --launcher.XXMaxPermSize is something that the launcher reads
(not the JVM); it tells the launcher to automatically size the JVM's
perm gen if it (the launcher) detects a Sun JVM that supports that
option. This alleviates the need to put it under -vmargs (where non-Sun
JVM's could fail because they don't understand that option)."
Previous Topic:Comment lines in eclipse.ini? Change from Eclipse GUI possible?
Next Topic:Upgrading from 3.5.2 to 3.6
Current Time: Sun Jul 20 08:52:56 EDT 2025
Powered by FUDForum. Page generated in 0.05043 seconds
