Home » Eclipse Projects » Remote Application Platform (RAP) » Wrong Composite width with Decoration
Wrong Composite width with Decoration [message #646960] Mon, 03 January 2011 10:28 Go to next message
When I create a Composite with a TextField and a Decoration associated to it, the width of the Composite is not big enought.
In fact, I cannot see the Decoration because the width is too small.
Is there a workaround for this issue ?
Re: Wrong Composite width with Decoration [message #647124 is a reply to message #646960] Tue, 04 January 2011 11:28 Go to previous messageGo to next message
you're talking about ControlDecoration, don't you?
This is not an issue but by intention. You have to leave some space for
the decorators in your layout.
From the ControlDecoration JavaDoc:
"Clients using ControlDecoration should typically ensure that enough
margin space is reserved for a decoration by altering the layout data
margins, although this is not assumed or required by the ControlDecoration
implementation."
HTH, Ralf
Ralf Sternberg
Twitter: @ralfstx
Re: Wrong Composite width with Decoration [message #647223 is a reply to message #647124] Wed, 05 January 2011 03:14 Go to previous message
Ok,
Thank you for this information.
Previous Topic:Launching a dialog on startup
Next Topic:Error handling in RAP, especially on Workbench Parts
Current Time: Sat Jul 19 10:53:39 EDT 2025
Powered by FUDForum. Page generated in 0.35716 seconds
