Home » Modeling » EMF » Exception thrown by transaction.commit() on an empty resource
Exception thrown by transaction.commit() on an empty resource [message #646942] Mon, 03 January 2011 06:30 Go to next message
I have an inconsistent behavior with CDO and I don't understand the problem.
Initially I have an empty database where the CDO server creates his tables "cdo_*" and "eresource_*". In my client code, I do a transaction.getOrCreateResource("R") and I add something using resource.getContents().add( MyObjectFactory.eINSTANCE.createSomething() ).
When I commit the changes on the transaction, I have the following exception:
org.eclipse.emf.cdo.util.CommitException: java.lang.UnsupportedOperationException
at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl. commit(CDOTransactionImpl.java:921)
at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl. commit(CDOTransactionImpl.java:932)
Caused by: java.lang.UnsupportedOperationException
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.doSave(Reso urceImpl.java:1438)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:1406)
at org.eclipse.emf.cdo.common.model.EMFUtil.getEPackageBytes(EM FUtil.java:254)
at org.eclipse.emf.cdo.common.model.CDOModelUtil.writePackage(C DOModelUtil.java:386)
at org.eclipse.emf.cdo.internal.common.model.CDOPackageUnitImpl .write(CDOPackageUnitImpl.java:267)
at org.eclipse.emf.cdo.internal.common.protocol.CDODataOutputIm pl.writeCDOPackageUnit(CDODataOutputImpl.java:79)
at org.eclipse.emf.cdo.internal.net4j.protocol.CommitTransactio nRequest.requestingCommit(CommitTransactionRequest.java:170)
at org.eclipse.emf.cdo.internal.net4j.protocol.CommitTransactio nRequest.requesting(CommitTransactionRequest.java:141)
at org.eclipse.emf.cdo.internal.net4j.protocol.CommitTransactio nRequest.requesting(CommitTransactionRequest.java:116)
at org.eclipse.net4j.signal.RequestWithMonitoring.requesting(Re questWithMonitoring.java:163)
at org.eclipse.net4j.signal.RequestWithConfirmation.doExtendedO utput(RequestWithConfirmation.java:117)
at org.eclipse.net4j.signal.Signal.doOutput(Signal.java:285)
at org.eclipse.net4j.signal.RequestWithConfirmation.doExecute(R equestWithConfirmation.java:102)
at org.eclipse.net4j.signal.RequestWithMonitoring.doExecute(Req uestWithMonitoring.java:233)
at org.eclipse.net4j.signal.SignalActor.execute(SignalActor.jav a:66)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:240)
at org.eclipse.net4j.signal.SignalProtocol.startSignal(SignalPr otocol.java:462)
at org.eclipse.net4j.signal.RequestWithConfirmation.doSend(Requ estWithConfirmation.java:87)
at org.eclipse.net4j.signal.RequestWithConfirmation.send(Reques tWithConfirmation.java:73)
at org.eclipse.net4j.signal.RequestWithMonitoring.send(RequestW ithMonitoring.java:108)
at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtoco l.send(CDOClientProtocol.java:375)
at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtoco l.commitTransaction(CDOClientProtocol.java:258)
at org.eclipse.emf.internal.cdo.transaction.CDOSingleTransactio nStrategyImpl.commit(CDOSingleTransactionStrategyImpl.java:7 3)
at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl. commit(CDOTransactionImpl.java:907)
... 45 more
*But*, if I first create something in the resource using Eclipse's CDO Sessions view, then the exact same code that threw the exception above will work perfectly.
So my question is: how do I add a first object in the resource from the client code?
Re: Exception thrown by transaction.commit() on an empty resource [message #646947 is a reply to message #646942] Mon, 03 January 2011 07:38 Go to previous messageGo to next message
Hi Julien,
You get better attention for CDO questions if you prefix the title with [CDO].
Comments below...
Am 03.01.2011 12:30, schrieb julien.jorge@acapnos.com:
> Quote:
>> ... 45 more
This is strange. Please tell me what the following statements print out:
System.out.println(MyObjectPackage.eINSTANCE);
System.out.println(MyObjectPackage.eINSTANCE.eResource());
Are you running standalone or within OSGi?
That's probably because the exception is caused by the remote registration of a *new* EPackage. If you already added an object of a class of that package your code would not try to commit the package again. The question is: Why does the CDOSessions view not fail with the same message. From the exception I can not see it. Maybe you can send me an executable example?
There are no special obligations.
Cheers
/Eike
http://www.esc-net.de
Re: Exception thrown by transaction.commit() on an empty resource [message #646948 is a reply to message #646947] Mon, 03 January 2011 07:43 Go to previous messageGo to next message
Please, if you can, add the following line to the beginning of EMFUtil.getEPackageBytes():
System.out.println(ePackage);
System.out.println(ePackage.eResource());
and tell me what they print out...
Cheers
/Eike
Am 03.01.2011 13:38, schrieb Eike Stepper:
> Hi Julien,
> Comments below...
>> Hi,
>> Quote:
>>> ... 45 more
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
Re: Exception thrown by transaction.commit() on an empty resource [message #646954 is a reply to message #646948] Mon, 03 January 2011 09:48 Go to previous messageGo to next message
Eike
The result is:
console
com.company.myobject.impl.MyObjectPackageImpl@65d9e279 (name: myobject) (nsURI: http://www.company.com/company/myobject, nsPrefix: com.company.myobject)
org.eclipse.emf.ecore.resource.impl.ResourceImpl@105585dc uri='http://www.company.com/company/myobject'
Eike
We are running without OSGi, from a BlazeDS server in Tomcat actually. Also, I did try to add a static main() in my class and run it from Eclipse as a Java application and ended with the same error.
Eike
Julien
I can't send you a running example but I can show you how I initialize the whole stuff. Maybe I did something wrong:
private CDOTransaction m_transaction;
private CDOSession m_session;
private IConnector m_connector;
private IManagedContainer m_container;
private CDOResource m_resource;
// The initialization is below
this.m_container = ContainerUtil.createContainer();
Net4jUtil.prepareContainer(this.m_container);
TCPUtil.prepareContainer(this.m_container);
CDONet4jUtil.prepareContainer(this.m_container);
this.m_container.activate();
this.m_connector = TCPUtil.getConnector(this.m_container, "localhost:2036");
CDOSessionConfiguration configuration = CDONet4jUtil.createSessionConfiguration();
configuration.setConnector(this.m_connector);
configuration.setRepositoryName( "MyRepository" );
this.m_session = configuration.openSession();
this.m_session.getPackageRegistry().putEPackage(MyObjectPackage.eINSTANCE);
this.m_transaction = this.m_session.openTransaction();
this.m_resource = this.m_transaction.getOrCreateResource("MyResource");
Eike
Unfortunately I have no access to EMFUtil source code.
Thanks for the quick feedback by the way Smile
Re: Exception thrown by transaction.commit() on an empty resource [message #646968 is a reply to message #646954] Mon, 03 January 2011 11:28 Go to previous messageGo to next message
Hi Julien,
I think Ed figured this out: You probably forgot to deploy org.eclipse.emf.ecore.xmi to your flat classpath.
Cheers
/Eike
Am 03.01.2011 15:48, schrieb julien.jorge@acapnos.com:
> Eike
> The result is:
> console
> Eike
> Eike
>> Julien
> this.m_session.getPackageRegistry().putEPackage(MyObjectPack age.eINSTANCE);
> Eike
> Thanks for the quick feedback by the way :)
Re: Exception thrown by transaction.commit() on an empty resource [message #646971 is a reply to message #646968] Mon, 03 January 2011 12:02 Go to previous messageGo to next message
Eike Stepper wrote on Mon, 03 January 2011 11:28
Hi Julien,
Indeed, that was the problem, thank you Smile But do you understand why the exception was not thrown when the database is non empty?
By the way, I have now a different exception:
org.eclipse.emf.cdo.util.CommitException: org.eclipse.net4j.signal.RemoteException: org.eclipse.emf.common.util.WrappedException: java.lang.ClassNotFoundException: com.company.myobject.MyObjectPackage
Caused by: org.eclipse.net4j.signal.RemoteException: org.eclipse.emf.common.util.WrappedException: java.lang.ClassNotFoundException: com.company.myobject.MyObjectPackage
at org.eclipse.net4j.signal.RequestWithConfirmation.setRemoteEx ception(RequestWithConfirmation.java:128)
at org.eclipse.net4j.signal.SignalProtocol.handleRemoteExceptio n(SignalProtocol.java:535)
at org.eclipse.net4j.signal.RemoteExceptionIndication.indicatin g(RemoteExceptionIndication.java:53)
at org.eclipse.net4j.signal.Indication.doExtendedInput(Indicati on.java:55)
at org.eclipse.net4j.signal.Signal.doInput(Signal.java:315)
at org.eclipse.net4j.signal.Indication.execute(Indication.java: 49)
at org.eclipse.net4j.signal.Signal.run(Signal.java:146)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPool Executor.java:1110)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoo lExecutor.java:603)
at java.lang.Thread.run(Thread.java:636)
Caused by: org.eclipse.emf.common.util.WrappedException: java.lang.ClassNotFoundException: com.company.myobject.MyObjectPackage
at org.eclipse.emf.ecore.plugin.RegistryReader$EPackageDescript or.getEPackage(RegistryReader.java:279)
at org.eclipse.emf.ecore.impl.EPackageRegistryImpl.getEPackage( EPackageRegistryImpl.java:133)
at org.eclipse.emf.cdo.internal.common.model.CDOPackageUnitImpl .loadPackageFromGlobalRegistry(CDOPackageUnitImpl.java:378)
at org.eclipse.emf.cdo.internal.common.model.CDOPackageUnitImpl .read(CDOPackageUnitImpl.java:288)
at org.eclipse.emf.cdo.internal.common.protocol.CDODataInputImp l.readCDOPackageUnit(CDODataInputImpl.java:105)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTra nsactionIndication.indicatingCommit(CommitTransactionIndicat ion.java:213)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTra nsactionIndication.indicating(CommitTransactionIndication.ja va:167)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTra nsactionIndication.indicating(CommitTransactionIndication.ja va:122)
at org.eclipse.net4j.signal.IndicationWithMonitoring.indicating (IndicationWithMonitoring.java:84)
at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedIn put(IndicationWithResponse.java:90)
at org.eclipse.net4j.signal.IndicationWithResponse.execute(Indi cationWithResponse.java:63)
at org.eclipse.net4j.signal.IndicationWithMonitoring.execute(In dicationWithMonitoring.java:63)
... 5 more
Caused by: java.lang.ClassNotFoundException: com.company.myobject.MyObjectPackage
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:506)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:422)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:410)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:266)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(Bund leLoader.java:338)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:232)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1197)
at org.eclipse.emf.ecore.plugin.RegistryReader$EPackageDescript or.getEPackage(RegistryReader.java:272)
... 17 more
I give you this only in the case it would be obvious for you but I will search on my side too.
Re: Exception thrown by transaction.commit() on an empty resource [message #646977 is a reply to message #646971] Mon, 03 January 2011 12:30 Go to previous message
Am 03.01.2011 18:02, schrieb julien.jorge@acapnos.com:
>> Hi Julien,
> Indeed, that was the problem, thank you :)
You're welcome.
From my first answer: That's probably because the exception is caused by the remote registration of a *new* EPackage. If you already added an object of a class of that package your code would not try to commit the package again.
Only new packages are serialized (in XMI format) to the server. In your case that happened from the CDOSessions view and there, in OSGI, the ecore.xmi plugin was properly deployed. Later, on your client the generated package was deployed. No need to serialize or deserialize it.
Cheers
/Eike
> Quote:
>> ... 5 more
>> ... 17 more
Previous Topic:WebIdl 2 Ecore ?
Next Topic:Generating reflective method implementation using EMF code generator
Current Time: Sat Jul 19 10:59:01 EDT 2025
Powered by FUDForum. Page generated in 0.03844 seconds
