Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF ECORE] EMF model
[EMF ECORE] EMF model [message #646731] Thu, 30 December 2010 10:59 Go to next message
HI,
How can I create a virgin example EMF from an existing EMF model without wizard.?
[Updated on: Thu, 30 December 2010 10:59] by Moderator
Re: [EMF ECORE] EMF model [message #646752 is a reply to message #646731] Thu, 30 December 2010 12:43 Go to previous messageGo to next message
ST,
I'm not sure I follow your question. What's a "virgin example EMF"?
ST wrote:
> HI,
> without wizard.
Re: [EMF ECORE] EMF model [message #647034 is a reply to message #646752] Tue, 04 January 2011 03:58 Go to previous messageGo to next message
Q1: how can I create an EMF model from a meta-model without using the wizards (which class use?) ?
Q2: I have a model "XML file", and I want to convert it to a model EMF ". ecore", how can I do it?
thx
Re: [EMF ECORE] EMF model [message #647111 is a reply to message #647034] Tue, 04 January 2011 11:02 Go to previous message
ST,
Comments below.
If you invoke Generate Test Code and check out the generated
XyzExample.java you'll see how it creates an instance of the model and
saves it to a resource.
Likely the XyzExample.java answer this question too.
> thx
Previous Topic:[EMF compare]
Next Topic:[TEXO] generating EOperations
Current Time: Sat Jul 19 10:01:50 EDT 2025
Powered by FUDForum. Page generated in 0.02346 seconds
