Home » Archived » M2M (model-to-model transformation) » [ATL] Adding entries to a Map attribute from imperative code
[ATL] Adding entries to a Map attribute from imperative code [message #645744] |
Mon, 20 December 2010 06:21  |
Hi all,
in a transformation, I have a attribute helper defined in the context of
the module. The User Guide tells me, that one can use those attributes
as a kind of global variable and explains that using an integer counter.
Now I'd like to do something like that using a Map.
--8<---------------cut here---------------start------------->8---
helper def: family2AddressMap : Genealogy!Address = Map(Families!Family, Genealogy!Address);
rule getAddress(f : Families!Family) {
to
a : Genealogy!Address (
street <- f.street,
town <- f.town
do {
thisModule.family2AddressMap <- (f, a);
a;
--8<---------------cut here---------------end--------------->8---
The attribute definition seems to be ok, but the assignment to the map
doesn't work. There are "no viable alternative at input" errors for the
"t" starting "thisModule" as well as for "f" and "a".
So how do I add an entry to a map?
In case you can see that I'm trying to reimplement the behavior of a
unique lazu rule, you are absolutily right. This is just for
educational purposes, and of course totally flawed. ;-)
Bye,
Tassilo
Dipl.-Inform. Tassilo Horn | Room: B015
University of Koblenz-Landau, Campus Koblenz | Phone: +49 (261) 287-2745
Institute for Software Technology | Mail: horn@uni-koblenz.de
Universitätsstr. 1, 56070 Koblenz, Germany |
Re: [ATL] Adding entries to a Map attribute from imperative code [message #645927 is a reply to message #645744] |
Tue, 21 December 2010 03:42   |
Le 20/12/2010 12:21, Tassilo Horn a écrit :
> Hi all,
May I suggest 'addressMap' as a name for the Map?
> to
> street<- f.street,
> town<- f.town
> do {
> thisModule.family2AddressMap<- (f, a);
thisModule.addressMap->put(f, a)
> a;
> Bye,
> Tassilo
Cordialement
Vincent MAHÉ
Ingénieur Expert - Projet IDM++ - Équipe AtlanMod
École des Mines de Nantes
La Chantrerie - 4, rue Alfred Kastler
B.P. 20722 - F-44307 NANTES Cedex 3
Tel: (33)2 51 85 81 00
Re: [ATL] Adding entries to a Map attribute from imperative code [message #645936 is a reply to message #645927] |
Tue, 21 December 2010 04:23   |
Vincent MAHE <vmahe@irisa.fr> writes:
Hi Vincent,
Of course you may.
>> to
>> street<- f.street,
>> town<- f.town
>> do {
Oh, that was clearly to obvious to me yesterday afternoon! ;-)
The ATL User Guide states that there are some further operations get(),
including(), union(), getKeys(), getValues() beside the "common
operations". What's "common" here?
Tassilo
Re: [ATL] Adding entries to a Map attribute from imperative code [message #645965 is a reply to message #645952] |
Tue, 21 December 2010 05:58  |
Hi Vincent,
>> get(), including(), union(), getKeys(), getValues() beside the
>> "common operations". What's "common" here?
> The operations inherited from OclAny upperclass (oclXxx and refXxx methods,
> debug(), toString())
Ah, I see. I had the impression that "common" refers to the Java Map
interface linked shortly above that sentence, and so I wondered why
there are getKeys() and getValues() where Map already declares keySet()
and values().
But then, put() should be listed in the user guide.
Bye,
Tassilo
Current Time: Sun Jul 20 08:11:19 EDT 2025
Powered by FUDForum. Page generated in 0.09074 seconds
