Home » Modeling » M2T (model-to-text transformation) » [Acceleo 3] Internal Error - installBundle - NullPointerException
[Acceleo 3] Internal Error - installBundle - NullPointerException [message #645683] Sun, 19 December 2010 14:57 Go to next message
in past (~half a year) I learned to use Acceleo and was able to use it for some use cases. However, with the newest bundles (Acceleo 3.0.1 or 3.1.0M4) together with Topcased/Eclipse 4.2.0 and 4.2.1 I am unable to start a Acceleo generation.
I want to start my M2T by using the IDE and a "Acceleo Application" configuration ("Acceleo Plug-In Application"). However, I get the following error:
An internal error occurred during: "Launching MyModel2Code".
at org.eclipse.acceleo.common.internal.utils.workspace.AcceleoWorkspaceUtil.installBundle(AcceleoWorkspaceUtil.java:877)
at org.eclipse.acceleo.common.internal.utils.workspace.AcceleoWorkspaceUtil.refreshContributions(AcceleoWorkspaceUtil.java:647)
at org.eclipse.acceleo.common.internal.utils.workspace.AcceleoWorkspaceUtil.getClass(AcceleoWorkspaceUtil.java:419)
at org.eclipse.acceleo.ide.ui.launching.strategy.AcceleoLaunchOperation.run(AcceleoLaunchOperation.java:97)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:1975)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:1957)
at org.eclipse.acceleo.ide.ui.launching.strategy.AcceleoPluginLaunchingStrategy.launch(AcceleoPluginLaunchingStrategy.java:220)
at org.eclipse.acceleo.ide.ui.launching.strategy.AcceleoPluginLaunchingStrategy.launch(AcceleoPluginLaunchingStrategy.java:124)
at org.eclipse.acceleo.internal.ide.ui.launching.AcceleoLaunchDelegate.launch(AcceleoLaunchDelegate.java:51)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:853)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:702)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:923)
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlugin.java:1126)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
The error happens even before any code of mine. I have absolutely no idea where to start solving this problem. My sources/project does not have any obvious error.
I also checked an Acceleo sample project. It did not work immediately, but finally it started and I was able to debug the MTL file.
Thanks in advance!
Re: [Acceleo 3] Internal Error - installBundle - NullPointerException [message #645686 is a reply to message #645683] Sun, 19 December 2010 16:50 Go to previous messageGo to next message
Oh... Crying or Very Sad
The more I try, the more errors I get. Right now, I am testing for 12 hours, and I still have no idea what's wrong.
I often get errors like "Structural feature 'lement' not found", "The feature 'lement' is not a valid feature" or "Structural feature 'uardian' not found". Yes, somehow the first letter of the feature gets swallowed (only experienced this with Acceleo 3.0.1).
However, I also get another very interesting error right now (sometimes). This error seems like a "meaningful error" (in contrast to the other ones). He tells me, that my class definition cannot be found (org/example/MyModelPackage). I cannot comprehend this error, because the file "org/example/MyModelPackage.class" exists. Its jar file is also in the build path of my Acceleo project. The according plug-in is also installed in my Eclipse environment. This is not enough? How is it possible, that he complains, that he cannot find the class definition?
	at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:421)
	at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:507)
	at org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog.run(ProgressMonitorJobsDialog.java:275)
	at org.eclipse.ui.internal.progress.ProgressManager$5.run(ProgressManager.java:960)
	at org.eclipse.ui.internal.progress.ProgressManager.busyCursorWhile(ProgressManager.java:995)
	at org.eclipse.ui.internal.progress.ProgressManager.busyCursorWhile(ProgressManager.java:970)
	at org.eclipse.ui.internal.progress.ProgressManager.run(ProgressManager.java:1166)
	at org.eclipse.acceleo.module.sample17.ui.popupMenus.AcceleoGenerateSampleAction.run(AcceleoGenerateSampleAction.java:91)
	at org.eclipse.ui.actions.ActionDelegate.runWithEvent(ActionDelegate.java:70)
	at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:241)
	at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
	at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
	at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4066)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3657)
	at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
	at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
Caused by: java.lang.NoClassDefFoundError: org/example/MyModelPackage
	at org.eclipse.acceleo.module.sample17.files.Generate.registerPackages(Generate.java:252)
	at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator.initialize(AbstractAcceleoGenerator.java:291)
	at org.eclipse.acceleo.module.sample17.files.Generate.<init>(Generate.java:83)
	at org.eclipse.acceleo.module.sample17.ui.common.GenerateAll.doGenerate(GenerateAll.java:88)
	at org.eclipse.acceleo.module.sample17.ui.popupMenus.AcceleoGenerateSampleAction$1.run(AcceleoGenerateSampleAction.java:76)
	at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
or
Caused by: java.lang.ClassNotFoundException: org/example/MyModelPackage
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:506)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:422)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:410)
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
	... 6 more
[Updated on: Sun, 19 December 2010 16:58] by Moderator
Re: [Acceleo 3] Internal Error - installBundle - NullPointerException [message #645733 is a reply to message #645686] Mon, 20 December 2010 04:52 Go to previous message
--------------060807060900090900070603
I don't really know what you've tested, but you seem to mix multiple
things here...
First things first : if you are developping Eclipse plugins, you should
never have to play with the build path or jar files. When you need to
add a dependency to your project, you open the META-INF/MANIFEST.MF
file, open the "dependencies" tab, then add the dependency from there.
Adding the jar file to the build path will only get you obscure errors.
The first error you got (with the "installBundle" trace) means that your
generator project has a dependency towards another project of your
workspace ... which is not a plugin or which has invalid MANIFEST.MF or
plugin.xml artifacts.
If you follow the "getting started" for Acceleo, do you still get these
errors :
- Create a New -> Acceleo Project
- Add dependencies from the MANIFEST.MF to the required projects
- Copy/paste your generators in this 'clean' project
- Try and launch the generation
Laurent Goubet
Obeo
On 19/12/2010 22:50, vultur wrote:
> Oh... :cry:
> I often get errors like "Structural feature 'lement' not found" or
> at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:421)
> at
> org.eclipse.jface.dialogs.ProgressMonitorDialog.run(Progress MonitorDialog.java:507)
> at
> org.eclipse.ui.internal.progress.ProgressMonitorJobsDialog.r un(ProgressMonitorJobsDialog.java:275)
> at
> org.eclipse.ui.internal.progress.ProgressManager$5.run(Progr essManager.java:960)
> at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
> at
> org.eclipse.ui.internal.progress.ProgressManager.busyCursorW hile(ProgressManager.java:995)
> at
> org.eclipse.ui.internal.progress.ProgressManager.busyCursorW hile(ProgressManager.java:970)
> at
> org.eclipse.ui.internal.progress.ProgressManager.run(Progres sManager.java:1166)
> at
> org.eclipse.acceleo.module.sample17.ui.popupMenus.AcceleoGen erateSampleAction.run(AcceleoGenerateSampleAction.java:91)
> at
> org.eclipse.ui.actions.ActionDelegate.runWithEvent(ActionDel egate.java:70)
> at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:241)
> at
> org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:584)
> at
> org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:501)
> at
> org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:4066)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3657)
> at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2640)
> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 38)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:664)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:115)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
> at
> org.eclipse.acceleo.module.sample17.files.Generate.registerP ackages(Generate.java:252)
> at
> org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator. initialize(AbstractAcceleoGenerator.java:291)
> at
> at
> org.eclipse.acceleo.module.sample17.ui.common.GenerateAll.do Generate(GenerateAll.java:88)
> at
> org.eclipse.acceleo.module.sample17.ui.popupMenus.AcceleoGen erateSampleAction$1.run(AcceleoGenerateSampleAction.java:76)
> at
> org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:121)
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------060807060900090900070603--
Previous Topic:Setting up mwe workflow file contents?
Next Topic:[Xpand] : runing workflows with ant or Maven
Current Time: Sat Jul 19 23:11:56 EDT 2025
Powered by FUDForum. Page generated in 0.04523 seconds
