Home » Modeling » TMF (Xtext) » Weird behaviour with multiple multi line comments
Weird behaviour with multiple multi line comments [message #645382] Thu, 16 December 2010 17:03 Go to next message
I am trying to implement something similar to java doc in xtext (because the language supports it). Currently I have multiple problems with Xtext.
1) There seems to be a weird bug. Consider the following example grammar:
grammar org.xtext.example.mydsl.MyDsl hidden(WS, DOC_COMMENT, ML_COMMENT, SL_COMMENT)
generate myDsl "http://www.xtext.org/example/mydsl/MyDsl"
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
Model:
	a='a';
terminal DOC_COMMENT: '/**' -> '*/';
terminal ML_COMMENT	: '/*' -> '*/';
terminal SL_COMMENT 	: '//' !('\n'|'\r')* ('\r'? '\n')?;
terminal WS			: (' '|'\t'|'\r'|'\n')+;
terminal ANY_OTHER: .;
This seems to show a very weird behaviour when using the compiled Editor. The following code:
a
*/<EOF>
works as expected. It seems to show weird behaviour when the end of File is on the next line or after a space, where the /** */ doesnt get lexed properly. If I remove one of the multiline comments (e.g. If I only have DOC_COMMENT and not ML_COMMENT) everything works as expected. If I change the characters for DOC_COMMENT everything works fine. Is this a bug or am i doing something horribly wrong? If this is the wrong approach, how would I go about doing this correctly?
I would love the DOC_COMMENT to be a production rule, but then I cannot color the whole text, and have other problems (e.g. cannot make the rule hidden)
Finally, I would also like to be able to nest a DOC_COMMENT inside a ML_COMMENT, is that possible at all?
Re: Weird behaviour with multiple multi line comments [message #645443 is a reply to message #645382] Fri, 17 December 2010 04:33 Go to previous messageGo to next message
I don't know what you are trying to do, but if you want to make the rule hidden anyway and not store (only doc) comments in the model, why not simply use only ML_COMMENT. If you want to process a doc comment, it does not really matter whether you check the name of the terminal rule or check whether the ML_COMMENT terminal actually starts with "/**".
Alex
Re: Weird behaviour with multiple multi line comments [message #645483 is a reply to message #645443] Fri, 17 December 2010 07:35 Go to previous messageGo to next message
Thanks for the answer. It turned out that it can be done by using such terminal rules:
terminal ML_COMMENT	: '/*'!'*' .* (DOC_COMMENT .*)* '*/';
The point was, to be able to have a different color for /** */ comments than for regular ML_comments, and DOC comments were allowed to be nested in regular comments:
e.g.
would translate to a single ML_Comment. With the default terminals, it would also give you a single ML_comment but also a trailing */ which would case a syntax error.
Re: Weird behaviour with multiple multi line comments [message #645500 is a reply to message #645483] Fri, 17 December 2010 09:03 Go to previous messageGo to next message
with your definition, do you get different highlighting for nested doc comments? I assume not. Also the comment "/**/" should cause a syntax error with your definition.
Regarding the syntax error for nested case with the default implementation, you are of course right.
Alex
Re: Weird behaviour with multiple multi line comments [message #645515 is a reply to message #645500] Fri, 17 December 2010 10:16 Go to previous messageGo to next message
yes, you are right, but the parser is required to be able to parse document comments inside multiline comments (because it is so in preexisting code, which is out of my control). It seems that there are no /**/ comment instances.
I have have yet to figure out if there is an alternative to that which allows for nested comments and the case /**/
Also, I was wondering, is it possible to write lexer fragments which can be used in terminals? Or do I have to use a custom lexer to do that?
Re: Weird behaviour with multiple multi line comments [message #645724 is a reply to message #645382] Mon, 20 December 2010 04:03 Go to previous message
We have a similar documentation feature in the context of hovers in
Xtext 2.0.
You could have a look at the source code for inspiration, especially
/org.eclipse.xtext/src/org/eclipse/xtext/documentation/impl/ MultiLineCommentDocumentationProvider.java
Am 16.12.10 23:03, schrieb Wattos@gmail.com:
> Model:
> a='a';
> a
> */<EOF>
> hidden)
Previous Topic:Hidden production rules?
Next Topic:combining JavaVMTypes and own types
Current Time: Sat Jul 19 15:37:04 EDT 2025
Powered by FUDForum. Page generated in 0.04311 seconds
