Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [EMFStore] performances problems & model division
[EMFStore] performances problems & model division [message #643876] |
Wed, 08 December 2010 10:08  |
Hi !
Today I have two questions (or three)... which are related
First question:
I've spoken a little about it with Maximilian, but I had no example to provide... So I have now an example project showing the problem:
download it here
or here
The problem is: when I create a big model (about 50000 objects), I have big performances problems (Checkout is really slow, the sample interface is really slow too...).
To use my example, you have to launch an EMF Store server including the two plugins, and to launch an eclipse environment with the two plugins. Then, open the "Library Sets Manager" view (into the "Library Set Exemple" category), click on the "connect" button of the opened view, and click on the "+" button to create and fill automatically a model (My model is odd because I wanted to make something which reflect my model in my real project, with several root objects).
I think that all interesting code is into the [EMFStoreExample]/src/example/manager/EMFStoreConnection.jav a file (I can paste it here if you want ?).
Second problem:
My solution has to be able to manage up to 1 000 000 objects... but I see that on the server, everything for a given project is stored into the same xmi file. Is it possible to change the server behavior in order to save data into separated files for each root object ?
Else, is it possible to make an external reference to an object contained by another project ? And is there no problem if I have a big number of projects ?
Bonus problem:
In my example project, when adding a book to a library, I have the following error (while adding others objects to each others or to the project don't raises any exception). (You encounter the problem when clicking the "+" button, which fill automatically the created LibrarySet)
Quote: | !ENTRY org.unicase.metamodel 4 4 2010-12-08 15:52:27.125
!MESSAGE Project Change Observer threw an exception again, but it will not be detached.example.manager.EMFStoreConnection$ProjectChangeLis tener
!STACK 0
at org.unicase.workspace.impl.ProjectChangeTracker.notify(Proje ctChangeTracker.java:203)
at org.unicase.metamodel.impl.ProjectImpl$2.run(ProjectImpl.jav a:436)
at org.unicase.metamodel.impl.ProjectImpl.notifyProjectChangeOb servers(ProjectImpl.java:373)
at org.unicase.metamodel.impl.ProjectImpl.handleEMFNotification (ProjectImpl.java:439)
at org.unicase.metamodel.util.ProjectChangeNotifier.notifyChang ed(ProjectChangeNotifier.java:132)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify (BasicNotifierImpl.java:380)
at org.eclipse.emf.ecore.util.EcoreEList.dispatchNotification(E coreEList.java:255)
at org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUniq ue(NotifyingListImpl.java:300)
at org.eclipse.emf.common.util.AbstractEList.add(AbstractEList. java:307)
at example.manager.EMFStoreConnection.createLibraries(EMFStoreC onnection.java:259)
at example.manager.EMFStoreConnection.access$3(EMFStoreConnecti on.java:242)
at example.manager.EMFStoreConnection$3.doRun(EMFStoreConnectio n.java:230)
at example.manager.EMFStoreConnection$3.doRun(EMFStoreConnectio n.java:1)
at org.unicase.workspace.util.UnicaseCommandWithResult.doExecut e(UnicaseCommandWithResult.java:35)
at org.eclipse.emf.transaction.RecordingCommand.execute(Recordi ngCommand.java:135)
at org.eclipse.emf.common.command.BasicCommandStack.execute(Bas icCommandStack.java:84)
at org.eclipse.emf.transaction.impl.AbstractTransactionalComman dStack.basicExecute(AbstractTransactionalCommandStack.java:2 41)
at org.unicase.workspace.changeTracking.commands.EMFStoreTransa ctionalCommandStack.basicExecute(EMFStoreTransactionalComman dStack.java:49)
at org.eclipse.emf.transaction.impl.TransactionalCommandStackIm pl.doExecute(TransactionalCommandStackImpl.java:63)
at org.eclipse.emf.transaction.impl.AbstractTransactionalComman dStack.execute(AbstractTransactionalCommandStack.java:165)
at org.eclipse.emf.transaction.impl.AbstractTransactionalComman dStack.execute(AbstractTransactionalCommandStack.java:219)
at org.unicase.workspace.util.UnicaseCommandWithResult.run(Unic aseCommandWithResult.java:52)
at example.manager.EMFStoreConnection.createLibrarySet(EMFStore Connection.java:234)
at example.manager.LibrarySetManager.runAddLibrarySet(LibrarySe tManager.java:177)
at example.manager.LibrarySetManager.access$0(LibrarySetManager .java:153)
at example.manager.LibrarySetManager$1.run(LibrarySetManager.ja va:74)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$6.handleEven t(ActionContributionItem.java:452)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:4066)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3657)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 38)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:664)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:115)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383
[Edit] : I changed my example, because it was creating only 50 books (while my problem is when much more objects are stored). The new version creates now 50 000 books per library.
[Updated on: Thu, 09 December 2010 03:45] by Moderator
Re: [EMFStore] performances problems & model division [message #643988 is a reply to message #643876] |
Wed, 08 December 2010 18:11   |
Hi Guillaume,
Thank you very much for preparing the example, that´s great!
Comments inline...
Maximilian
> http://www.4shared.com/file/CJez2ElN/EMF_Store_Example_-_plu gins.html
Unfortunately the provided link does not work for me: "The file link
that you requested is not valid.". Maybe you can upload the file here?:
http://rapidshare.com/
I have tested the EMFStore with 100.000+ elements recently (although
with a quite simple structure), so this is odd, probably something that
I did not take into consideration. I will look into it, once the example
goes online.
> Second problem:
Yes it is possible, there is one method in the server which is
responsible for this. There is no extension point to change it in custom
code yet, but I could add an extension point for this if required.
This is currently not possible, it is on the feature list, but not yet
scheduled.
Seems to be you custom class
example.manager.EMFStoreConnection$ProjectChangeListener which throws
the null pointer exception. But I can look into it once the uploaded
example is available.
> Quote:
>> !STACK 0
>> java.lang.NullPointerException
>> coreEList.java:255)
>> onnection.java:259)
>> on.java:242)
>> n.java:230)
>> ngCommand.java:135)
>> dStack.java:49)
>> tManager.java:177)
>> .java:153)
>> (Realm.java:332)
>> bench.java:664)
>> tarter.java:369)
>> tarter.java:179)
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
>> at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
>> at java.lang.reflect.Method.invoke(Unknown Source)
>> at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
Re: [EMFStore] performances problems & model division [message #644041 is a reply to message #643988] |
Thu, 09 December 2010 03:44   |
Hi !
Rapidshare seems to be locked by my enterprise... I tried with another service.
new link here
Yes, I would be really interested by this feature (Can I sill making cross references between root objects (or their sub-objects) even if they are not stored in the same file on server ? Does it have some impact on the revision operation ?).
> scheduled.
If the file division (just above), and performances are here, references between projects is not a need for me for now
Re: [EMFStore] performances problems & model division [message #644074 is a reply to message #644048] |
Thu, 09 December 2010 05:00   |
>> references between projects is not a need for me for now Smile
> After consideration, it appears that the references between projects is
> something blocking for us, because our model contains several parts: a
> main part used by every one, and sub-parts using the main part. But
> sub-parts have not to be accessed by everyone, so making a global
> checkout including all sub-parts is not possible (some data are
> critical, we cannot store them on the computer of non authorized
> people): we should checkout sup-parts separately... which means into
> deferent projects with EMF Store, making the link with the main part (in
> another project) impossible :-/
> Perhaps is there another existing solution to make separate checkouts ?
> But this missing feature is really a problem for us :(
I do not think it is very complicated to implement. We have already
implemented something quite similar. It is more a question of resources.
If you need it fast, we can help you to implement it and you make a
contribution to the EMFStore concerning this feature. What is the time
frame you would need this feature in?
Maximilian
Re: [EMFStore] performances problems & model division [message #644075 is a reply to message #644074] |
Thu, 09 December 2010 05:13   |
another service.
> new link here
Thanks, now it worked, I will look into it tomorrow and get back to you!
order
Yes cross references between root nodes are no problem even if they are
in different files, that is already the case on the client side.
Maximilian
Re: [EMFStore] performances problems & model division [message #648325 is a reply to message #644075] |
Wed, 12 January 2011 07:28  |
I looked into your example. There is a two things that I changed:
- You created one model element (e.g. a book) and then added it to the
project directly and repeated this 50.000 times. The EMFStore will track
each addition as a single change, so it records 50.000 changes. It is a
lot faster to first create a library with 50.000 books and then to add
it to the project. It will then be tracked as one change only.
- NPE: You subclassed ProjectChangeTracker and added it as a
ProjectChangeObserver. The ProjectChangeTracker was not initialized
therefore it threw an exception. Anyway it is easier to just implement
the interface ProjectChangeObserver. This is what I did, the NPE is gone.
I have tested the example with 100.000 model elements now and it works
fine. It takes about a minute to initially commit the newly created
100.000 elements. Follow-up commits with less changes take about a
second on the same project.
I uploaded the changed code along with a Team Project Set of the current
trunk version of the EMFStore:
http://rapidshare.com/files/442159179/EMFStoreExampleRevised .zip
Hope this helps!
Maximilian
Am 09.12.2010 11:13, schrieb Maximilian Koegel:
> another service.
> > new link here
> order
> custom
> Cheers,
> Maximilian
Current Time: Sat Jul 19 07:07:37 EDT 2025
Powered by FUDForum. Page generated in 0.06804 seconds
