Home » Modeling » M2T (model-to-text transformation) » [Acceleo 3] continuous integration on acceleo projects(automate acceleo project builds to use with a continuous integration server)
[Acceleo 3] continuous integration on acceleo projects [message #641129] Wed, 24 November 2010 06:02 Go to next message
I want to set up a continuous integration server (hudson) to check the health of acceleo projects.
Let's take a classical configuration:
  • a source code management system (svn)
  • one (or several) project(s) with metamodel(s)
  • one (or several) acceleo project(s) with modules/templates
  • one (or several) project(s) with models used to test accede generation
What is continuous integration (CI)? If a commit occurs on the SVN, the CI server checks the latest revision (project sources) out, launches the build and the test suite.
In order to be able to do that with acceleo, I need to be able to build (outside eclipse) and package (jar) in an automated way acceleo projects. Then, I need to run acceleo projects on input models for test purposes.
What is the good way to do that?
Is an integration with maven possible?
Christophe.
Re: [Acceleo 3] continuous integration on acceleo projects [message #641139 is a reply to message #641129] Wed, 24 November 2010 06:52 Go to previous messageGo to next message
Continuous Integration is possible with maven :
First make a wrapper (Ant or maven) for acceleo compiler (packaged in AcceleoParser jar file).
Build your mtl files with this compiler.
Write a maven plugin for you acceleo project.
Use this plugin to generate code from your model
That's it
Sebastien
Re: [Acceleo 3] continuous integration on acceleo projects [message #641160 is a reply to message #641139] Wed, 24 November 2010 08:11 Go to previous messageGo to next message
Sebastien Roy wrote on Wed, 24 November 2010 06:52
I saw there is already an ant task: http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.m2t/org .eclipse.acceleo/plugins/org.eclipse.acceleo.parser/src-ant/ org/eclipse/acceleo/parser/compiler/AcceleoCompiler.java?vie w=markup&revision=1.14&root=Modeling_Project
Is it usable?
What about dependencies? Is there a maven/ivy repository with acceleo and all its dependencies available? If not, is it possible to publish it?
If this is not possible, what are the required dependencies for a standalone execution of acceleo?
Christophe.
Re: [Acceleo 3] continuous integration on acceleo projects [message #641354 is a reply to message #641160] Thu, 25 November 2010 02:45 Go to previous messageGo to next message
--------------020205030505000402010405
Hi Christophe,
I believe that Sebastien could help more than myself, since he managed
to get the compilation running standalone in his environment. I had
written this part of the FAQ :
http://wiki.eclipse.org/Acceleo/FAQ#How_can_I_compile_my_mtl _files_in_a_standalone_environment.3F
with information on this if it can help.
Laurent Goubet
Obeo
>> Hello,
> Is it usable?
> Quote:
> Regards,
> Christophe.
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------020205030505000402010405--
Re: [Acceleo 3] continuous integration on acceleo projects [message #641472 is a reply to message #641160] Thu, 25 November 2010 10:33 Go to previous messageGo to next message
I use the AcceleoCompiler class through a delegation mechanism.
The reason is to register the resources before actual execution of AcceleoCompiler task.
Here is my code :
public class MavenMtlCompiler extends AbstractMojo {
	 * @parameter property="sourceFolders"
	private String sourceFolders;
	AcceleoCompiler acceleoCompiler = new AcceleoCompiler();
	public MavenMtlCompiler() {
	public void setSourceFolders(String value) {
		acceleoCompiler.setSourceFolders(value);
    public void execute() throws MojoExecutionException {
    	//displayClassPath();
    	registerLibraries();
    	acceleoCompiler.execute();
	private void displayClassPath() {
        ClassLoader sysClassLoader = ClassLoader.getSystemClassLoader();
        //Get the URLs
        URL[] urls = ((URLClassLoader)this.getClass().getClassLoader()).getURLs();
        getLog().info("----------------------- Classpath --------------------");
        for(int i=0; i< urls.length; i++) {
            getLog().info(urls[i].getFile());
        getLog().info("------------------------------------------------------");
    private void registerLibraries() {
		Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put("ecore", new EcoreResourceFactoryImpl());
		Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put("uml", UMLResource.Factory.INSTANCE);
		Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put("emtl", new EMtlResourceFactoryImpl());
		EPackage.Registry.INSTANCE.put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
		EPackage.Registry.INSTANCE.put("http://www.eclipse.org/uml2/2.1.0/UML", UMLPackage.eINSTANCE);
		CodeSource acceleoModel = MtlPackage.class.getProtectionDomain().getCodeSource();
		if (acceleoModel != null) {
			String libraryLocation = acceleoModel.getLocation().toString();
			if (libraryLocation.endsWith(".jar")) {
				libraryLocation = "jar:" + libraryLocation + '!';
			URIConverter.URI_MAP.put(URI.createURI("http://www.eclipse.org/acceleo/mtl/3.0/mtlstdlib.ecore"), URI.createURI(libraryLocation + "/model/mtlstdlib.ecore"));
			URIConverter.URI_MAP.put(URI.createURI("http://www.eclipse.org/acceleo/mtl/3.0/mtlnonstdlib.ecore"), URI.createURI(libraryLocation + "/model/mtlnonstdlib.ecore"));
		} else {
			getLog().error("Coudln't retrieve location of plugin 'org.eclipse.acceleo.model'.");
I made my own maven repository with acceleo dependencies :
	<dependencies>
		<!-- Acceleo -->
		<dependency>
			<groupId>org.eclipse.acceleo</groupId>
			<artifactId>org.eclipse.acceleo.engine</artifactId>
			<version>${acceleoVersion}</version>
		</dependency>
		<dependency>
			<artifactId>org.eclipse.acceleo.model</artifactId>
		</dependency>
		<dependency>
			<artifactId>org.eclipse.acceleo.common</artifactId>
		</dependency>
		<dependency>
			<artifactId>org.eclipse.acceleo.parser</artifactId>
		</dependency>
		<dependency>
			<artifactId>acceleoCompiler</artifactId>
		</dependency>
		<!-- EMF -->
		<dependency>
			<groupId>org.eclipse.emf</groupId>
			<artifactId>org.eclipse.emf.ecore</artifactId>
			<version>${emfVersion260}</version>
		</dependency>
		<dependency>
			<artifactId>org.eclipse.emf.ecore.xmi</artifactId>
			<version>${emfVersion250}</version>
		</dependency>
		<dependency>
			<artifactId>org.eclipse.emf.common</artifactId>
		</dependency>
		<dependency>
			<artifactId>org.eclipse.emf.codegen.ecore</artifactId>
		</dependency>
		<!-- UML2 -->
		<dependency>
			<groupId>org.eclipse.uml2</groupId>
			<artifactId>org.eclipse.uml2.uml</artifactId>
			<version>${uml2UmlVersion}</version>
		</dependency>
		<dependency>
			<artifactId>org.eclipse.uml2.common</artifactId>
			<version>${uml2CommonVersion}</version>
		</dependency>
		<!-- OCL -->
		<dependency>
			<groupId>org.eclipse.ocl</groupId>
			<artifactId>org.eclipse.ocl</artifactId>
			<version>${oclVersion}</version>
		</dependency>
		<dependency>
			<artifactId>org.eclipse.ocl.ecore</artifactId>
		</dependency>
		<!-- Eclipse -->
		<dependency>
			<groupId>org.eclipse.core</groupId>
			<artifactId>org.eclipse.core.runtime</artifactId>
			<version>${eclipseRuntimeVersion}</version>
		</dependency>
		<dependency>
			<groupId>org.eclipse.equinox</groupId>
			<artifactId>org.eclipse.equinox.common</artifactId>
			<version>${equinoxVersion}</version>
		</dependency>
		<dependency>
			<artifactId>org.eclipse.equinox.registry</artifactId>
			<version>${equinoxRegistryVersion}</version>
		</dependency>
		<dependency>
			<groupId>org.eclipse</groupId>
			<artifactId>org.eclipse.osgi</artifactId>
			<version>${osgiVersion}</version>
		</dependency>
		<!-- Misc -->
		<dependency>
			<groupId>net.sourceforge.lpg</groupId>
			<artifactId>lpg.runtime.java</artifactId>
			<version>${lpgVersion}</version>
		</dependency>
	</dependencies>
With the versions :
		<acceleoVersion>3.0.1.v201011180511</acceleoVersion>
		<emfVersion260>2.6.0.v20100614-1136</emfVersion260>
		<emfVersion250>2.5.0.v20100521-1846</emfVersion250>
		<uml2UmlVersion>3.1.0.v201006071150</uml2UmlVersion>
		<uml2CommonVersion>1.5.0.v201005031530</uml2CommonVersion>
		<oclVersion>3.0.0.v201005061704</oclVersion>
		<lpgVersion>2.0.17.v201004271640</lpgVersion>
		<osgiVersion>3.6.0.v20100517</osgiVersion>
		<equinoxVersion>3.6.0.v20100503</equinoxVersion>
		<equinoxRegistryVersion>3.5.0.v20100503</equinoxRegistryVersion>
		<eclipseRuntimeVersion>3.6.0.v20100505</eclipseRuntimeVersion>
Here is a script to deploy your packages (package must be present in the script directory):
set REPO=V:/mvn_rep/releases
set INSTALL=install:install-file
set DEPLOY=deploy:deploy-file
set TASK=%DEPLOY%
set COMMON_ARGS= %TASK% -Dpackaging=jar -DrepositoryId=starsRep -Durl=file:%REPO%
rem Acceleo
set ACCELEO_VERSION=3.0.1.v201011180511
set EMF_VERSION_260=2.6.0.v20100614-1136
set EMF_VERSION_250=2.5.0.v20100521-1846
set UML2_UML_VERSION=3.1.0.v201006071150
set UML2_COMMON_VERSION=1.5.0.v201005031530
set OCL_VERSION=3.0.0.v201005061704
set LPG_VERSION=2.0.17.v201004271640
set OSGI_VERSION=3.6.0.v20100517
set EQUINOX_VERSION=3.6.0.v20100503
set EQUINOX_REGISTRY_VERSION=3.5.0.v20100503
set ECLIPSE_RUNTIME_VERSION=3.6.0.v20100505
call mvn %COMMON_ARGS% -DgroupId=org.eclipse.acceleo -DartifactId=org.eclipse.acceleo.engine -Dversion=%ACCELEO_VERSION% -Dfile=org.eclipse.acceleo.engine_%ACCELEO_VERSION%.jar
call mvn %COMMON_ARGS% -DgroupId=org.eclipse.acceleo -DartifactId=org.eclipse.acceleo.model -Dversion=%ACCELEO_VERSION% -Dfile=org.eclipse.acceleo.model_%ACCELEO_VERSION%.jar
call mvn %COMMON_ARGS% -DgroupId=org.eclipse.acceleo -DartifactId=org.eclipse.acceleo.parser -Dversion=%ACCELEO_VERSION% -Dfile=org.eclipse.acceleo.parser_%ACCELEO_VERSION%.jar
call mvn %COMMON_ARGS% -DgroupId=org.eclipse.acceleo -DartifactId=org.eclipse.acceleo.common -Dversion=%ACCELEO_VERSION% -Dfile=org.eclipse.acceleo.common_%ACCELEO_VERSION%.jar
call mvn %COMMON_ARGS% -DgroupId=org.eclipse.acceleo -DartifactId=acceleoCompiler -Dversion=%ACCELEO_VERSION% -Dfile=acceleoCompiler_%ACCELEO_VERSION%.jar
rem uml2
call mvn %COMMON_ARGS% -DgroupId=org.eclipse.uml2 -DartifactId=org.eclipse.uml2.uml -Dversion=%UML2_UML_VERSION% -Dfile=org.eclipse.uml2.uml_%UML2_UML_VERSION%.jar
call mvn %COMMON_ARGS% -DgroupId=org.eclipse.uml2 -DartifactId=org.eclipse.uml2.common -Dversion=%UML2_COMMON_VERSION% -Dfile=org.eclipse.uml2.common_%UML2_COMMON_VERSION%.jar
rem emf
call mvn %COMMON_ARGS% -DgroupId=org.eclipse.emf -DartifactId=org.eclipse.emf.common -Dversion=%EMF_VERSION_260% -Dfile=org.eclipse.emf.common_%EMF_VERSION_260%.jar
call mvn %COMMON_ARGS% -DgroupId=org.eclipse.emf -DartifactId=org.eclipse.emf.ecore -Dversion=%EMF_VERSION_260% -Dfile=org.eclipse.emf.ecore_%EMF_VERSION_260%.jar
call mvn %COMMON_ARGS% -DgroupId=org.eclipse.emf -DartifactId=org.eclipse.emf.ecore.xmi -Dversion=%EMF_VERSION_250% -Dfile=org.eclipse.emf.ecore.xmi_%EMF_VERSION_250%.jar
call mvn %COMMON_ARGS% -DgroupId=org.eclipse.emf -DartifactId=org.eclipse.emf.codegen.ecore -Dversion=%EMF_VERSION_260% -Dfile=org.eclipse.emf.codegen.ecore_%EMF_VERSION_260%.jar
rem ocl
call mvn %COMMON_ARGS% -DgroupId=org.eclipse.ocl -DartifactId=org.eclipse.ocl.ecore -Dversion=%OCL_VERSION% -Dfile=org.eclipse.ocl.ecore_%OCL_VERSION%.jar
call mvn %COMMON_ARGS% -DgroupId=org.eclipse.ocl -DartifactId=org.eclipse.ocl -Dversion=%OCL_VERSION% -Dfile=org.eclipse.ocl_%OCL_VERSION%.jar
rem misc
call mvn %COMMON_ARGS% -DgroupId=net.sourceforge.lpg -DartifactId=lpg.runtime.java -Dversion=%LPG_VERSION% -Dfile=lpg.runtime.java_%LPG_VERSION%.jar
rem osgi
call mvn %COMMON_ARGS% -DgroupId=org.eclipse -DartifactId=org.eclipse.osgi -Dversion=%OSGI_VERSION% -Dfile=org.eclipse.osgi_%OSGI_VERSION%.jar
call mvn %COMMON_ARGS% -DgroupId=org.eclipse.core -DartifactId=org.eclipse.core.runtime -Dversion=%ECLIPSE_RUNTIME_VERSION% -Dfile=org.eclipse.core.runtime_%ECLIPSE_RUNTIME_VERSION%.jar
call mvn %COMMON_ARGS% -DgroupId=org.eclipse.equinox -DartifactId=org.eclipse.equinox.common -Dversion=%EQUINOX_VERSION% -Dfile=org.eclipse.equinox.common_%EQUINOX_VERSION%.jar
call mvn %COMMON_ARGS% -DgroupId=org.eclipse.equinox -DartifactId=org.eclipse.equinox.registry -Dversion=%EQUINOX_REGISTRY_VERSION% -Dfile=org.eclipse.equinox.registry_%EQUINOX_REGISTRY_VERSION%.jar
I hope it will help
Re: [Acceleo 3] continuous integration on acceleo projects [message #643882 is a reply to message #641129] Wed, 08 December 2010 10:32 Go to previous messageGo to next message
Thanks for all the posts on this topic, I also am trying to set up a hudson CI build to
1) compile the MTL files
2) compile associated .java files
3) execute the code generator
using this thread and an earlier one I have almost achieved the goal.
final issue is that my source .uml file "MyModel.uml" references another .uml file that is an associated profile - "MyProfile.uml".
When executing the code generator (using the exec:java plugin for maven and the acceleo 'Generate.class' file for my templates) I get an error:
"Package with uri 'http:///schemas/MyProfile/_uxGMcPi2Ed-z3tfFFpxgGA/0' not found. (file:.../MyModel.uml)"
of course everything works fine from within eclipse. My guess is that the profile needs to be registered...but is not all the needed info in the MyModel.uml file?
what am I missing?
many thanks
Re: [Acceleo 3] continuous integration on acceleo projects [message #643888 is a reply to message #643882] Wed, 08 December 2010 10:37 Go to previous messageGo to next message
--------------030906040605020506050308
We've had a few people ask here how to use Acceleo in standalone with
profiled UML models ... And I must admit I don't know the exact things
that are to be done in order to register UML profiles. You should ask
this on the eclipse.modeling.mdt.uml newsgroup.
When you do get a valid answer on this point, could you point me to the
exact code needed for the registration for further reference?
Laurent Goubet
Obeo
On 08/12/2010 16:32, D.H.Akehurst wrote:
> hudson CI build to
> what am I missing?
> many thanks
--------------030906040605020506050308--
Re: [Acceleo 3] continuous integration on acceleo projects [message #643914 is a reply to message #641129] Wed, 08 December 2010 11:55 Go to previous messageGo to next message
It appears that you don't need to do anything different to register a profile.
Provided there is a full path name to the main model.
The acceleo Generate.java:main method takes two arguments. The first is the filename of the model to generate over. When this is a relative path, it can't find the referenced profile, when it is a full path name, the profile is found fine.
Re: [Acceleo 3] continuous integration on acceleo projects [message #644046 is a reply to message #643914] Thu, 09 December 2010 03:45 Go to previous messageGo to next message
--------------060403030504020903010006
And thanks, at least this gives me a potential answer for the people
who'll come after you :).
Laurent Goubet
Obeo
> profile.
--------------060403030504020903010006--
Re: [Acceleo 3] continuous integration on acceleo projects [message #644149 is a reply to message #644046] Thu, 09 December 2010 11:53 Go to previous messageGo to next message
Hi Laurent
This may be another symptom of Bug 318137 and/or Bug 306692.
Ed
On 09/12/2010 08:45, Laurent Goubet wrote:
> Laurent Goubet
> Obeo
>> profile.
Re: [Acceleo 3] continuous integration on acceleo projects [message #644782 is a reply to message #644149] Tue, 14 December 2010 03:44 Go to previous message
--------------090500000401050007070608
Hi Ed,
Doesn't look like it.
Laurent Goubet
Obeo
On 09/12/2010 17:53, Ed Willink wrote:
> Hi Laurent
> Regards
> Ed
>> Hi,
>> Laurent Goubet
>> Obeo
>>> profile.
--------------090500000401050007070608--
Previous Topic:Acceleo Compiler
Next Topic:[Acceleo] Nested model transformation
Current Time: Sat Jul 19 17:06:35 EDT 2025
Powered by FUDForum. Page generated in 0.05391 seconds
