Home » Eclipse Projects » Remote Application Platform (RAP) » TinyMCE can't working with RAP1.4M3
TinyMCE can't working with RAP1.4M3 [message #641039] Tue, 23 November 2010 21:48 Go to next message
Hi All:
I have use the TinyMCE on my application, I found a question that the
TinyMCE custom widget can't working only with RAP1.4M3, but It is
working with RAP1.4M2 and the earlier version , who can give me some
advice? thanks!
Best Regards!
Roy
Re: TinyMCE can't working with RAP1.4M3 [message #641070 is a reply to message #641039] Wed, 24 November 2010 02:42 Go to previous messageGo to next message
Hi Roy,
what does it mean - not working? Are there any javascript errors? Could
you provide simple test project with TinyMCE to test it?
Thnaks,
Ivan
On 24.11.2010 4:48 AM, Roy wrote:
> Hi All:
> advice? thanks!
> Best Regards!
> Roy
Re: TinyMCE can't working with RAP1.4M3 [message #641087 is a reply to message #641070] Wed, 24 November 2010 03:52 Go to previous messageGo to next message
--------------030205020008010201060608
Content-Type: text/plain; charset=GB2312
Hi Ivan:
The attached file is my test plug-ins!
Best Regards!
Roy
Re: TinyMCE can't working with RAP1.4M3 [message #641088 is a reply to message #641070] Wed, 24 November 2010 03:54 Go to previous messageGo to next message
--------------010300030602080602000102
Hi Ivan:
The attached file is my test plug-ins!(the main)
Best Regards!
Roy
Re: TinyMCE can't working with RAP1.4M3 [message #641113 is a reply to message #641070] Wed, 24 November 2010 05:02 Go to previous messageGo to next message
Hi Ivan :
The attached file is my test plug-ins, there is a rich text, a text, a
button in the view of the main plug-in , when i insert some word into
the rich text, and click the button , then the text will display the
text of the rich text . when i run it with rap1.4M2 , it is Ok , but
with rap1.4M3, the text can't display the right result !
Best Regards!
Roy
于 2010年11月24日 15:42, Ivan Furnadjiev 写道:
> Hi Roy,
> Thnaks,
> Ivan
>> Hi All:
>> advice? thanks!
>> Best Regards!
>> Roy
Re: TinyMCE can't working with RAP1.4M3 [message #641157 is a reply to message #641039] Wed, 24 November 2010 08:00 Go to previous messageGo to next message
Hi Roy,
in 1.4M3 we removed this internal field:
org_eclipse_rap_rwt_EventUtil_suspend
See bug:
328915: [client] Refactor org_eclipse_rap_rwt_EventUtil_suspend
https://bugs.eclipse.org/bugs/show_bug.cgi?id=328915
To make it work again please change in TinyMCE.js:
if( !org_eclipse_rap_rwt_EventUtil_suspend ) {
to
if( !org.eclipse.swt.EventUtil.getSuspended() ) {
Best,
Ivan
Re: TinyMCE can't working with RAP1.4M3 [message #641329 is a reply to message #641157] Wed, 24 November 2010 21:52 Go to previous message
Hi Ivan:
Thanks a lot!
Best Regards!
Roy
于 2010年11月24日 21:00, Ivan Furnadjiev 写道:
> Hi Roy,
> See bug:
> to
> Best,
> Ivan
Previous Topic:Direct Entry URLs possible?
Next Topic:Doing POST to external server
Current Time: Sat Jul 19 05:08:25 EDT 2025
Powered by FUDForum. Page generated in 0.06920 seconds
