Home » Eclipse Projects » Eclipse Platform » How to get a reference to a Browser
How to get a reference to a Browser [message #640562] Mon, 22 November 2010 09:00 Go to next message
How can I get a reference to a org.eclipse.swt.Browser from a WebBrowserEditor or from a org.eclipse.ui.IWebBrowser.
Or do you know other way to get the content of a WebBrowserEditor? (Browser would suffice since this has the getText() method)
Thanks!
Re: How to get a reference to a Browser [message #640575 is a reply to message #640562] Mon, 22 November 2010 09:15 Go to previous messageGo to next message
On 11/22/2010 15:00, Gabriel Petrovay wrote:
Have you tried this (from a Google search, untested):
IWebBrowser webBrowser = browser.createBrowser
(IWorkbenchBrowserSupport.LOCATION_BAR |
IWorkbenchBrowserSupport.AS_EDITOR |
IWorkbenchBrowserSupport.NAVIGATION_BAR |
IWorkbenchBrowserSupport.STATUS, null,"TestBrowser", "TestBrowser");
URL url = ...;
webBrowser.openURL(url);
HTH & Greetings from Bremen,
- Daniel Krügler
Re: How to get a reference to a Browser [message #640576 is a reply to message #640575] Mon, 22 November 2010 09:19 Go to previous messageGo to next message
>> Hi,
> URL url = ...;
Here something that lloks like a helper functionality for web browsers:
http://www.koders.com/java/fid2383AEBC81C69847012A8E7408F354 8615ED13D8.aspx?s=calendar#L18
> - Daniel Krügler
Re: How to get a reference to a Browser [message #640582 is a reply to message #640575] Mon, 22 November 2010 09:38 Go to previous messageGo to next message
Hi Daniel,
I already have the browser open. I want to read the contents out of it. The org.eclipse.swt.Browser object has the getText() method to read it. But I want to get a reference to such an object?
The IWorkbenchBrowserSupport gives me only the org.eclipse.ui.browser.IWebBrowser (if I had the id, assume that I have it)
So I need to get a Browser from a IWebBrowser.
I don't see a solution in the link you send either. Thanks anyway!
Any ideas?
Re: How to get a reference to a Browser [message #640619 is a reply to message #640582] Mon, 22 November 2010 10:35 Go to previous messageGo to next message
There doesn't look to be a solution, at least not one with API. The
Browser is a field in org.eclipse.ui.internal.browser.BrowserViewer
which is in turn held in the
org.eclipse.ui.internal.browser.WebBrowserEditor
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: How to get a reference to a Browser [message #640659 is a reply to message #640619] Mon, 22 November 2010 12:53 Go to previous message
This is the current hack that I do.
Control[] childs = ((Composite)editor.getWidget()).getChildren();
if (childs.length > 0 && (childs[0] instanceof Composite)) {
    Composite comp = (Composite)childs[0];
    childs = comp.getChildren();
    if (childs.length > 0 && (childs[0] instanceof BrowserViewer)) {
        text[0] = ((BrowserViewer)childs[0]).getBrowser().getText();
I have it but I have to do it. Any other better solutions?
Previous Topic:Efficient update of workspace with new config spec
Next Topic:Preferences Not Passed Through to AntRunner in 3.6.1
Current Time: Sat Jul 19 09:54:39 EDT 2025
Powered by FUDForum. Page generated in 0.28883 seconds
