Home » Modeling » M2T (model-to-text transformation) » [Acceleo] ESE2010 Tutorial(Details regarding the tutorial "Creacting a language for Android Apps with Eclipse modeling")
[Acceleo] ESE2010 Tutorial [message #639286] Mon, 15 November 2010 17:16 Go to next message
I followed the (very interesting) Xtext-Acceleo tutorial at the ESE 2010.
I am trying to reproduce the Acceleo part of the tutorial, but I am facing a lack of details in the slides regarding the launch of the Acceleo generation.
I tried to configure a new run configuration as described in the Acceleo doc, and pointing to the contact.android model (Xtext file). The problem is that Acceleo does not seem to be able to parse this file as it is not an xmi file.
What did I miss?
How can I launch an Acceleo generation based on a model edited using Xtext?
Thanks beforehand,
Christophe
Re: [Acceleo] ESE2010 Tutorial [message #639345 is a reply to message #639286] Tue, 16 November 2010 03:00 Go to previous messageGo to next message
Hi Christophe,
We can generate code on this file because xText has defined a ResourceFactory for this type of files.
You should launch an Eclipse runtime (with Acceleo and xText installed) with these projects:
org.eclipse.ese.android.dsl
org.eclipse.ese.android.dsl.ui
org.eclipse.ese.android.model
Then, launch a second Eclipse runtime from the first one (right click, Run As, Eclipse Application), this will deploy the xText editor for the .android files (which will provide everything needed for us to manipulate .android files as models) and then, have fun Smile
Stéphane Bégaudeau, Obeo.
[Updated on: Tue, 16 November 2010 03:01] by Moderator
Re: [Acceleo] ESE2010 Tutorial [message #639377 is a reply to message #639345] Tue, 16 November 2010 05:18 Go to previous message
Thank you for this quick and clear answer
Previous Topic:How to run MWE2 workflow from my application
Next Topic:[Xpand] Template could not be found
Current Time: Sat Jul 19 14:18:58 EDT 2025
Powered by FUDForum. Page generated in 0.03982 seconds
