Home » Modeling » GMF (Graphical Modeling Framework) » Fixed source and target for connection
Fixed source and target for connection [message #639243] Mon, 15 November 2010 12:57 Go to next message
I have a connetion between source and target. Is there any way to prevent the changin of the source or target of connection once it is connected between two elements. I have gone through
GraphicalNodeEditPolicy , ConnectionEndPointsPolicy and ConnectionEditPolicy for this. I am confused which is the one i need to use
My investigation :In GraphicalNodeEditPolicy i have found that the methods responsible for handling reconnection are :
getReconnectSourceCommand(ReconnectRequest r)
getReconnectTargetCommand(ReconnectRequest r)
i have tried to override these methods and set the command an request to null so that reonnect action is not done. But it does not solve the problem and the connection can be moved. Can anybody provide some help here.
Re: Fixed source and target for connection [message #639248 is a reply to message #639243] Mon, 15 November 2010 13:02 Go to previous messageGo to next message
did you try to return an UnexecutableCommand instead of null?
regards,
Re: Fixed source and target for connection [message #639268 is a reply to message #639248] Mon, 15 November 2010 14:33 Go to previous messageGo to next message
Not sure how to create an unexecutable command Sad
The input I get in this method is request. Do i need to set any properties for the request.?
Re: Fixed source and target for connection [message #639312 is a reply to message #639268] Mon, 15 November 2010 20:21 Go to previous message
sowmya wrote on Mon, 15 November 2010 14:33
It goes something like:
return UnexecutableCommand.INSTANCE
- Asiri
Previous Topic:Remove item in Context menu when creating new Node?
Next Topic:How can I get the position from a model.
Current Time: Sat Jul 19 14:56:19 EDT 2025
Powered by FUDForum. Page generated in 0.05255 seconds
