Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [TEXO] EMF databinding
[TEXO] EMF databinding [message #635799] |
Thu, 28 October 2010 03:59  |
is there a API for the Texo databinding with a eclipse RCP.
EMF has EMFObservables with undo/redo support.
EMFObservables.observeValue(myEObject,
MyPackage.Literals.MYNAME__NAME)
Is there a possibilty to use the undo/redo support and the databinding with EMFT?
Re: [TEXO] EMF databinding [message #635826 is a reply to message #635822] |
Thu, 28 October 2010 05:38   |
Hello Martin,
thanks again for your answer =).
Yes that was my idea too.
- Texo on the server with EclipseLink
- EMF on the client with EMFEditProperties
So I just need a Wrapper which convert the client EMF Object to Texo pojos.
Do you know a Util class for convert the objects?
Or how can I save the client emf objects on the server side which are generated by texo?
Martin taal wrote on Thu, 28 October 2010 05:21 | Hi Wayne,
I asked around and this is the answer I got from Tom Schindl:
BeanBinding currently does not support undo/redo and EMFObservables does
neither. The only one providing this feature currently is EMFEditObservables
(deprecated) and EMFEditProperties.
There's an open bug for BeanBinding to add such a support. Since 3.6 IIRC
the fundamental low level API is
available but nobody stepped up to implement something similar to
EMF-Commands on top of it (who is responsible to for the undo/redo support).
Texo is currently targeted mainly for the server side and the above means that databinding support for pojos does not
support undo/redo.
So assuming that you do an rcp I would go for this scenario:
gr. Martin
On 10/28/2010 09:59 AM, SirWayne wrote:
> Hello,
> with EMFT?
> Thanks
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
[Updated on: Thu, 28 October 2010 05:45] by Moderator
Re: [TEXO] EMF databinding [message #635830 is a reply to message #635826] |
Thu, 28 October 2010 05:54   |
Hi Wayne,
See here:
http://wiki.eclipse.org/Texo/Convert_to_EMF
For Model to EMF:
This conversion will convert the whole object graph (traversing all references). I can imagine that you don't want to
traverse the whole object graph (loading all the data from the database). I would like to improve the converter to
handle this better, so let me know what type of changes/extendability you need to make this work (if needed).
For EMF to Model:
Here you probably need to read referenced objects from the db while converting, also let me know what type of
extendability you need to make this work.
Let me know if there are possibilities to have standard eclipselink/jpa object resolvers and uri generation which can be
used as part of the conversion and which can be added to Texo (I am always interested in contributions here).
gr. Martin
On 10/28/2010 11:38 AM, SirWayne wrote:
> Hello Martin,
> Yes that was my idea too. - Texo on the server with EclipseLink
>> Hi Wayne,
>> EMFEditObservables
>> support).
>> means that databinding support for pojos does not support undo/redo.
>> gr. Martin
>> > Hello,
>> > with EMFT?
>> > Thanks
>> The Netherlands
The Netherlands
Re: [TEXO] EMF databinding [message #636594 is a reply to message #636560] |
Tue, 02 November 2010 02:51   |
I now read the stack trace of the class cast exception a bit better... It happens in the static initializer of the
TestFactory. What I don't understand is why this static initializer has not been called already earlier before Texo
replaces the EFactory of the EPackage. Can you put a breakpoint in the constructor of the TestEPackage, there should be
a line there like this:
super(eNS_URI, TestFactory.eINSTANCE);
which should already initialize the TestEFactory.eINSTANCE before Texo places its own EFactory in the TestEPackage. The
replacement of the EFactory happens in the ModelEFactory.getEPackage method, maybe you can put a breakpoint there to to
see when that gets called.
Btw, I am starting to doubt that Texo should replace the EFactory of the generated EPackage... But never the less, what
you try to do should work fine, afaics.
gr. Martin
On 11/01/2010 10:35 PM, SirWayne wrote:
> Okay i will try it.
> it's very confusing to have 2 Classes with the same name. And it's very
> difficult to explain which you have to use
The Netherlands
Re: [TEXO] EMF databinding [message #638377 is a reply to message #637962] |
Thu, 11 November 2010 00:24   |
Hi Michael,
The issue with the classcastexception and the missing id efeature seems to be solved by forcing initialization of the
EMF client ModelPackage before the EMF Texo ModelModelPackage:
public void createPartControl(Composite parent) {
// just call any method on the ModelPackage to force its initialization
ModelPackage.eINSTANCE.getNsURI();
ModelModelPackage.initialize();
Another place to do this forced initialization is in a plugin Activator for example.
Note that in my idea the client should not have Texo code but just generated EMF code. The serialization between the
client and the server can use XML or in the future json (working on that).
gr. Martin
On 11/09/2010 02:35 PM, Martin Taal wrote:
> Hi Wayne,
> Okay, I have not yet received your email did you use: mtaal at
> springsite.com? You can also try mtaal at elver.org.
> gr. Martin
> On 11/09/2010 01:52 PM, SirWayne wrote:
>> Hello Martin,
>> i send you a mail at your springsite addy with a little example.
>> Additional i try to debug the problem.
The Netherlands
Re: [TEXO] EMF databinding [message #639154 is a reply to message #638972] |
Mon, 15 November 2010 07:36   |
Hi Martin,
could you show your idea?
I should don't use texo code on the client, correct?
Where do i have to do the conversion?
And how works the serialization ?I can only serialization the pojos or?
My Code idea:
Client Side:
private String writeXMI(final List<Object> objects) {
final ModelXMLSaver xmlSaver = new ModelXMLSaver();
xmlSaver.setSaveAsXMI(true);
xmlSaver.setObjects(objects);
final StringWriter sw = new StringWriter();
xmlSaver.setWriter(sw);
xmlSaver.write();
return sw.toString();
emf.client.Object object =...
object.setName("test huhu");
List<Object> objects = new ArrayList<Object>();
objects.add(verwaltung);
String xmi = writeXMI(objects);
baseService.saveOrUpdate(xmi);
Problem: I can only serialization pojos not the emf objects or?
java.lang.IllegalStateException: The class class emf.client.Object is not managed by this ModelResolver
Server Side: (Do here the conversion???)
public <T extends DBObject> T saveOrUpdate(String xmi) {
List<Object> objects = readXML(xmi);
System.out.println(objects);
return null;
private List<Object> readXML(final String xml) {
final ModelXMLLoader xmlLoader = new ModelXMLLoader();
xmlLoader.setLoadAsXMI(true);
xmlLoader.setReader(new StringReader(xml));
return xmlLoader.read();
gr. Michael
Martin taal wrote on Sun, 14 November 2010 00:12 | Hi Michael,
See this wiki doc:
http://wiki.eclipse.org/Texo/XML_and_XMI_Serialization
gr. Martin
On 11/11/2010 09:10 PM, SirWayne wrote:
> Martin taal wrote on Thu, 11 November 2010 00:24
>> Hi Michael,
>> generated EMF code. The serialization between the client and the
> Yes but i don't want to serialize the EMF Objects, cause they have more
> dependency and they are greater.
> Serialize the objects with xml is a good idea.
> At time I use the Spring HttpInvoker so i have a interface for remote
> calls. Do you know a possibilty or tutorial how i can do the
> serialization with xml?
The Netherlands
Re: [TEXO] EMF databinding [message #639327 is a reply to message #639154] |
Tue, 16 November 2010 00:48   |
Hi Michael,
Can you try the following:
1- On the server: serialize Texo objects to xmi or xml
2- On the client: de-serialize the xmi/xml using a standard EMF XML/XMI resource
and to persist work the other way: serialize EMF objects using a standard XML/XMI resource and de-serialize on the
server using the Texo approach.
So on the client the xml/xmi is de-serialized directly to EMF objects without using Texo there.
Note, that there is one missing feature with the serialization on the Texo side: currently it will traverse all object
associations and serialize them all (effectively reading the complete database...). The plan for the coming 1-2 weeks is
to let this be done differently (use EMF proxies to serialize to xml, and read from the database when de-serializing to
Texo).
I have been busy with both Teneo and CDO the past few days, but that work is finished. So I hope to spend some days on
json serialization and the above logic (to not read the complete database). But it will be another week or so before
this is part of the Texo build....
gr. Martin
On 11/15/2010 01:36 PM, SirWayne wrote:
> Hi Martin,
> My Code idea:
> Client Side:
> xmlSaver.write();
> @Override
> return null;
> Thanks
> gr. Michael Martin taal wrote on Sun, 14 November 2010 00:12
>> Hi Michael,
>> See this wiki doc:
>> gr. Martin
>> >> Hi Michael,
>> The Netherlands
The Netherlands
Re: [TEXO] EMF databinding [message #639646 is a reply to message #639636] |
Wed, 17 November 2010 05:20   |
Hi Michael,
Great!
As I mentioned in the previous email the thing I am working on is:
- prevent loading of non-containment associations on the server, so send these as proxies/references to the client
- when updating resolve proxies on the server by reading from the database
- support individual proxy resolving in the resource used on the client
On the client you would be using a specific EMF resource delivered by Texo (is the only Texo specific code needed on the
client). This Texo/EMF resource implements the same api as the XMI/XML resource so theoritically (and hopefully
practically) you can develop your client against this resource api and then later switch to the EMFTexoResource.
And then next to supporting XMI/XML also support json as the data transfer format.
It is all clear in my mind what to develop, just need some time...
Can I contact you next week for a zip file of your then current workspace? Then I can test the above functionality with
your most up-to-date version.
gr. Martin
On 11/17/2010 11:08 AM, SirWayne wrote:
> Okay i send a file to the server
> Here is a example, if you want the whole workspace i could send you a mail:
> client side:
> private File writeXMI(final List<EObject> objects) {
> XMLResource xmiResource = new
> XMIResourceImpl(URI.createFileURI("test.xmi"));
> xmiResource.getContents().addAll(objects); try {
> xmiResource.save(null);
> } catch (IOException e) {
> return new File(xmiResource.getURI().toFileString());
> private List<EObject> loadXMI(File file) {
> XMLResource xmiResource = new XMIResourceImpl();
> try {
> xmiResource.load(new FileInputStream(file), null);
> } catch (FileNotFoundException e1) {
> } catch (IOException e1) {
> return xmiResource.getContents();
> ClientModelPackage.initialize();
> client.DBObject dbObject= ClientFactory.eINSTANCE.createDBObject();
> dbObjectsetName("test huhu");
> List<EObject> objects = new ArrayList<EObject>();
> File xmi = writeXMI(objects);
> xmi = service.saveOrUpdate(xmi);
> List<EObject> dbObjects = loadXMI(xmi);
> System.out.println(dbObjects.get(0));
> server side:
> import texo.model.DBObject;
> public class BaseServiceImpl implements BaseService{
> private Logger logger = LoggerFactory.getLogger(BaseServiceImpl.class);
> @Autowired
> private BaseDao baseDao;
> public BaseServiceImpl (){
> //do in activator only for example
> VerwaltungModelPackage.initialize();
> @Override
> @Transactional(propagation = Propagation.REQUIRED)
> public File saveOrUpdate(File xmi) {
> final List<DBObject> objects = readXML(xmi);
> final List<DBObject> dbObjects = new ArrayList<DBObject>();
> for(DBObject object : objects){
> dbObjects.add(baseDao.saveOrUpdate(object));
> return writeXML(dbObjects);
> private List<DBObject> readXML(final File xml) {
> try {
> xmlLoader.setReader(new FileReader(xml));
> } catch (FileNotFoundException e) {
> logger.error("file not found",e);
> List<DBObject> list = new ArrayList<DBObject>();
> for(Object object : xmlLoader.read()){
> list.add((DBObject) object);
> return list;
> private File writeXML(List<DBObject> list) {
> final ModelXMLSaver modelXMLSaver = new ModelXMLSaver();
> modelXMLSaver.setSaveAsXMI(true);
> final File file = new File("saveResult.xmi");
> try {
> modelXMLSaver.setWriter(new FileWriter(file));
> logger.error("save error", e);
> List<Object> objects = new ArrayList<Object>(list);
> modelXMLSaver.setObjects(objects);
> modelXMLSaver.write();
> return file;
> Thanks a lot it works =). I have to implement Util class to write/load
> the xmi files. So i can do the conversion on client side in the controller.
The Netherlands
Re: [TEXO] EMF databinding [message #639912 is a reply to message #635799] |
Thu, 18 November 2010 06:50  |
Hi Martin,
i send you a mail with a example workspace.
I have a question. Is it a good idea to send the file to the server?
Or should i send the OutputStream from the client to the server?
Current Time: Sat Jul 19 13:01:39 EDT 2025
Powered by FUDForum. Page generated in 0.08057 seconds
